Who makes the best conversion kit for the X3?
I have seen alot of kits that use a gas spring and other that do not. Is the gas spring really needed?
Pat
Pat
Triump
There are a few
CNCfusion http://www.cncfusion.com/ .....Not the best IMO others may differ
Syil from China http://www.syil.cn/ .....Look at a thread I have going for more info
Promica http://www.cnckits.com.au/ ......Looks good to me.
KDN Tool & Automation are supposed to be developing one. Don't know much about them.
I don't doubt there are others.
Some have used a gas spring successfuly others say it takes away from the rigidity of the head. Seems like a good idea to me.
Overall the Syil kit seems to be good quality. He uses higher quality ballscrews with preloaded nuts and angular contact bearings. I have not purchased this kit, but I do not believe there is sufficient documentation. ALso, there is a significant language barrier.
If it was me, I think I would go with the CNCkits one. It also utilizes angular contact bearings, looks clean and well made.
thanks for your kind conclusion for our products.of course we will sent the instuction in future to every clients.Originally Posted by phantomcow2
The PROMiCA kit includes full instructions with photo's and/or drawings identifying each and every part in the kit along with the appropriate relationship to corresponding components from the X3 itself. Instructions also cover possible 'gotchas' and clearly identify step by step the process all the way from removing the existing components, through the new fit-out, on to wiring the kit and finally dedicated instructions on configuring the supplied Mach3 software.... basically 'go to woe' is covered... and if you still get stuck then there's email support too (usually less than 24hr turn-around).
I should point out that the instructions supplied are appropriate for the kit purchased ... ie if the kit doesn't include the controller and software then the instructions relating to those components isn't included.
Thanks GreoIt & phantomcow2 for your support & praise!
Triump, I notice that some of those kits vary in price by hundreds of dollars. If you're like most of us, budget plays a big factor in your choice.
Hey phantomcow, do you know what brand those ballscrews are that come with the syil kit, or where they are made?
Mhuett,
Welcome aboard!!!!
Who makes The PROMiCA kit. Is there a website link?
Ron
According to my google search, the Promica kit is the name of the one at the CNCkits.au website.
The CNCkits one is 750 I think for a mechanical kit, plus shipping. THe Syil is 900 plus shipping. Either way shipping wont be cheap coming from across the globe!
Oilman, I don't know who manufactures the ballscrews Syil uses. You should probably ask him, I remember reading him saying that they are made in Italy.
Are you trying to avoid the standard black rolled ballscrew most use? I am almost positive that Nook industries makes higher grade ballscrews like Syil uses. You may have to buy from them directly though, I've not seen it offered by retail. Ask them for a quote.
Also, Hiwin makes higher grade rolled and ground ballscrew. THis I know for a fact. You may be able to ask them for a quote as well. I don't know if any Hiwin retailers, maybe automation4less.com?
You should enquire with CNCkits as to cost. He sugested to me freight to the USA would only be about $50Originally Posted by phantomcow2
I'm on a pretty limited budget, so I'm looking at the Fusion ballscrew kit, its $549. I should be able to order it, a xylotex board, power supply, enclosure, steppers, cables, etc.. and come in under $900, depending on shipping charges. I think I can replace the balls in the ballnuts myself to achieve a preload and save a little $$ there as well.
I also emailed Fusion about install instructions, and they are supposed to be very close to finishing an installation video. I dont know, we'll see.
I was wanting to go the the manufacturer web page of the ballscrews that syil uses. Curious as to the manufacturers posted specs on them.
Ron111 ...the website for PROMiCA is http://www.cnckits.com.au.
Regarding shipping ...
When I first approached Australia Post regarding the costs for shipping to the US I was misquoted ...in typical style they entered the incorrect weight and then gave me the SEA only rates!!
Shipping can be relatively cheap but it comes down to how quickly people want to recieve their goods which is why I don't include shipping in the base price. I prefer to determine the best method to suit the customer ... somebody on a tight budget may prefer to wait a bit longer and have it shipped by sea ...the next person however may want it tomorrow ... and that winds up the charges accordingly.
For example ... 3 days delivery door to door from Australia to the US is around $350 Australian or approx $260 US ... 9-12 weeks by sea is around $130Au or $97US. It also depends on what is purchased (ie which kit) ... the hardware only kit is much lighter than a full kit (hardware, motors, wiring & controller).
Have a look at the offered kit levels and determine which kit you are after ..then send an email using the links provided on the website and let me know where you are and how quickly you want the kit delivered (there is some lead time at the moment too...) ...I will email back all of your options ... it doesn't cost you anything other than your time..... happy to help!!
You may find it suits you to order just the hardware and then source motors and controller locally for example ... I sell complete kits but also will provide individual parts.
I will also work with people to modify the kit to suit the various models as there are several out there ...varying in column height, table length etc. And with those that I'm working with to create these various models I won't just make it then dump you ...if it is right I'll keep going until it is - I want to have a good name and reputation of helping.
Regards
Marc
Just be aware that kit does not have proper dual angular contact bearings as the others do. Need to compare apples with applesOriginally Posted by OilMan
It reuses the existing bearings which IMO are inadequate when aplying the greater forces involved in CNC over manual.
How much axial force is a 400oz/in nema23 motor is capable of generating when used with a 5TPI ballscrew? I ran the drive torque calculator formula thats on rockfordballscrew.com, and it looks like not more than 500lbs. (bearing in mind my math skills may be a little off, but I think thats pretty close)
The closest bearings I can find to the ones that come with the X3, on McMaster.com, part #6681K12 and are rated at 2110lbs. Lets say the sieg bearings are inferior, which they probably are, they should at least handle a 1000lb load?
I also looked up the angular contact bearings, the cheap ones, part #6680K12 $23, are rated at 1711lbs dynamic. Thrust load was not listed. The expensive ones, HOLY COW $133!! each! part# 2385K31 are rated at 1231lbs.
Now heres my question, am I likely to generate the kind of forces that require these expensive bearings? I know they are the "proper" way to install a ballscrew, but i'm not retrofitting a Haas or a Mazak super mill. This is just a small hobby thing for me, and I need it to be as in-expensive as possible. Besides, if the stock bearings give me trouble, couldn't i buy my own angle bearings with the $250 plus i will save?
PS: who has the best deal on gecko drives? homeshopcnc?
Oilman
I think my comment was not put well.
There must be a combination of bearing and retaining method to get the best out of it.
The kit in question uses a lock collar of some sort to preload and carry the force in that direction. No thread and nut.
See this thread http://www.cnczone.com/forums/showth...1&page=1&pp=15
It's a long thread and the relevant bit is well down.
Apart from being difficult to set a proper preload (no backlash) it then must withstand the forces on rapid change of direction.
This is not going to help much, but...
When you factor all the parts and hassles the 3 kits seem to be competitively priced given what they offer... Because things are so complicated and because I could easily butcher one or more expensive parts I decided to add 15-20% more, 1-2 months waiting, dealing with customs and the docks and just get a turn-key (minus the software) machine.
If I already had another mill and if I was looking at the conversion "as a project" as opposed to just "wanting the end result" perhaps I would have gone for a kit.
One of the main questions is probably whether you have access to another mill since with the Syil kit you will need to machine the base to make room for the Z-axis motor. OTOH I kind of like that all screws, even the Z axis, are direct driven. I guess the other question then becomes if you prefer direct drive or belt driven screws.
Hmmm... I'm not sure if the Ausie motors are microstep like the Syil's. Are they? I read someplace that microstep diminishes vibration. I think it was here: http://www.arceurotrade.co.uk/projec...CNC/index.html <= very nice article on an X3 conversion.
Being a noob I was also kind of surprised on how much work (and money) goes into converting a machine
WE also notice that AUS conversion suppliers.them have good price,hehe,but i think our ballscrew was better.so price a little higher.also,i think we use different Z-axis brackets between them.different motor.too...
we will post some details of our ballscrew,step motor,and other accessories,and our new factroy,new products in future coming soon.
any good advise please info us too.
Ok i think understand now, (MAN that other post was long, whew!)
So with a nut threaded on the end of the ballscrew, the stock bearings would perform fine, because preloading them would be simple. But the shaft collar on the Fusion kit makes it tough to get a preload on the thrust bearings.
I'm gonna send them an email saying i am interested in their kit, but i have concerns about the shaft collars. Mabye link them to that long post too. We'll see just how "open" to suggestions they are to improve their product.
Hey Ed, i wouldn't worry much about belt driven steppers/ballscrews, if you look at the design of most industrial $$$ cnc machines, many use timing belts between the servo and ballscrew. My guess is if the pros use timing belts, they will work great for us hobby guys.
PSS: geckos, geckos..... lowest price??
It does not say on the website. At least not that I could see.Originally Posted by Ed from NY
However in answer to my query, CNCkits told me that microstepping is configurable.
Best thing would be ask Marc. He posted earlier in this thread.
The PROMiCA kit does implement microstepping which is user configurable ...
Currently the kit requires a couple of tapped holes in the existing lower Z mount however I am currently desiging an all new replacement lower Z mount which means that there would be no modifications necessary (ie you can take the X3 from manual to CNC control without any additional holes, mods or column removal).
Marc
EDIT:
I should point out that by lower Z mount I mean the lower Z mounting bracket that is inside the column - it needs to be removed in order to fit the new Z leadscrew so while it's out you simply drill & tap two 6mm or (1/4") holes in the bottom of it and optionally a further 2 X 4mm in the side to hold a brace .... none need to be overly accurate and so can be done with a hand drill.
Hello..
Just a couple of questions regarding the Promica kits.
I noticed the Ballscrews are not Double Nut or pre-loaded like the Syil Kits. Obviously there will be less resolution without the Double nut... How much does pre-loaded Ballscrews add to the Kit price. Then we could compare the Syil Kit to oyurs.
Also what Drivers are you using.. Geckos???...
Noticed you are using Belt drives.... No matter how good the belts are they will be some backlash... IMHO direct Drive is better. Steppers are better at lower RPM anyway...
cheers
Frans
