586,068 active members*
3,823 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > M03 spin up delay still there, even after setting the value to 0 in spindle setup
    Dec 2009
    35
    Does anyone know if the spindle delay parameter is controlled from somewhere other than Ports and Pins / Spindle Setup?
    I recently removed the need for the delay, and set the values to 0, but it still waits whenever it encounters an M3 in the code.
    Steve
    http://www.stephenhobley.com/blog
    Laser Harps, Tesla Coils, and Killer Robots from Outer Space
    Re: M03 spin up delay still there, even after setting the value to 0 in spindle setup
    Are you using a vfd and if so does it have a parameter for ramp up internal to vfd???
  1. Spindle startup delay / dwell..
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2013, 06:07 AM
  2. Setting up pwm signal for Spindle in Mach3 - copying setup from emc/linuxcnc.
    By craynerd in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2012, 08:00 AM
  3. New Mach 3 Setup - Motors Don't Spin
    By LTHOMPS in forum Mach Software (ArtSoft software)
    Last Post: 11-10-2010, 10:05 PM
  4. Spindle delay
    By mkc2 in forum Mach Mill
    Last Post: 01-06-2009, 01:56 PM
  5. mach 3 spindle delay
    By mike10 in forum Mach Mill
    Last Post: 05-10-2008, 05:50 AM
