Hi all,
Im at my wits end fiddling around with this and Id really appreciate some hints about how to solve it.
The basic issue is with a Solidworks assembly.
I have a frame made from ITEM aluminium profiles (its pretty similar to 8020 but metric).
I was gifted a load of it along with a set of linear guides by a very decent fellow. After sitting on it for a good while as I accumulated other bits I've made a start at last. The linear bits are 14mm ground rod that sits in a sort of cup extrusion that sits in the profiles slot with trucks that have 2 types; one with fixed wheels and one type with adjustable wheels.
To model my frame I used the CAD models from the ITEM catalogue, its an installable bit of software and as well as doing loading calcs etc it'll export to just about any CAD system.
Service
The trucks are exported as pre done assemblies, and Im really struggling to mate the wheels to the rod. I want to be able to work out clearances and dimensions from the model so I want to have proper contact between the parts rather than an approximation.
I've attached a couple of screengrabs, one I've MSPAINTed to highlight the areas of interest.
Im also going to try attaching a zipped up copy of the assembly with its parts.
The top level assembly is called BaseAndGantry.
I've seen this thread:
http://www.cnczone.com/forums/solidw...s-rolling.html
but its not a completely analogous situation.
I suspect part of the problem is that the inside face of the wheel may have been modelled as 2 truncated cones facing each other with a cylinder joining them, and solidworks doesnt want to mate the cones in the wheels with the cylinder of the rail.
I would have thought a tangent mate was required, but its grayed out (over constrained?). I've tried every mate option I can find and Im pulling my hair out.
Hopefully someone has faced this sort of thing before, but I've searched the net, viewed a ton of videos, and searched a load of forums with no luck.
Thanks for having a look, JHAttachment 244610Attachment 244612
