586,067 active members*
5,089 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > 2006 machine motors are out of sync
    Dec 2010
    11
    i have a 5 x 12 router with a rotary and some time ago the z drive would trip "limit switch" if i ran it passed 50ipm and now the drive on the side opposite x0 y0 consistently runs 3/8 from the reset switch block no matter turning the machine off, clamping the switch closed, tighten the turn buckle and switch the machine on ... run a tool path and hit zero out and it is 3/8" from the limit stop
    Dec 2010
    11
    Re: 2006 machine motors are out of sync
    should be august 2008 machine
  1. Assistance comparing used machine specs for Joe's 2006
    By vthowe in forum Joes CNC Model 2006
    Last Post: 05-04-2012, 04:50 PM
  2. 2006 dmv diamond series is this a good machine
    By powerstream in forum Daewoo/Doosan
    Last Post: 07-06-2010, 09:05 PM
  3. Joe's 2006 Question on size of cutters machine will handle??
    By Rooney in forum Joes CNC Model 2006
    Last Post: 11-19-2009, 05:55 PM
