586,062 active members*
4,697 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > need help with multiple setups Acramatic 2100
    Dec 2011
    41
    Hello
    I have a Arrow 500 with Acramatic 2100 control I have a long run job with 8 setups (no problems running it). At the end of the program I have to go to the control and push
    Setups-Activate Setups-Machine-Cycle Start
    If the program finishes with no errors I would like to just push Cycle Start
    Can I do this and how?
    David
    David Rogers
    Meadholm Technologies
    Dec 2006
    584
    Re: need help with multiple setups Acramatic 2100
    What do you mean by 8 setups?? Do you mean 8 parts using 1 setup?? If so have you used fixture (H) offsets?? Does each setup have a different program?? Be more specific.
    Mike cncmachineservices (dot) com
    Dec 2011
    41
    Hello all
    I would like to say thanks for all the help I have received here. I first learned G code on a Haas VFOE and Mitsubishi M50 so I am having a problem getting my head around the Acramatic handles work coordinates
    I am running one program per part on 8 parts defined under the Multiple Setup page. Each part has a defined setup (xyz) so the program loops on each part till #8 and stops. It is very inefficient and meckart55 made me think about G54,G55 ect so is (H1) offset the same as G54 and how do you define them (where is the table).
    What is the syntax for calling H1 x0y0
    How would call G82 drill on all 8 H,s
    Have to go I need to load the beast
    David
    David Rogers
    Dec 2011
    41
    I am doing this on 8 parts(setups)
    N50(MSG,T16 SPOT DRILL)
    N60G80 G40 M09
    N70G28
    N80M06T16
    N90M03 S2500 M08 F10.0
    N100G0X0.98425 Y1.65354 Z0.5
    N110G81 X0.98425Y1.65354Z-0.145 R0.2 F10.0
    N120G80
    N130G0 Z0.5
    N140G80 G40 M09 M05
    N150M5 G28
    N160M01
    N170(MSG,END TOOL)
    M30
    (Can I do this)
    N60G80 G40 M09
    N70G28
    N80M06T16
    N110G81 H1 X0.98425 Y1.65354 Z-0.145 R0.2 F10.0
    H2 X0.98425 Y1.65354 Z-0.145
    H3 X0.98425 Y1.65354 Z-0.145
    H4 X0.98425 Y1.65354 Z-0.145
    (ECT
    N120G80
    N130G0 Z0.5
    N140G80 G40 M09 M05
    N150M5 G28
    N160M01
    N170(MSG,END TOOL)
    David Rogers
    Dec 2006
    584
    Yes, you can use this format. You need to put in the difference position for each of the 8 parts in the (H) offset number. Look in the books that came with the machine.
  1. Replies: 13
    Last Post: 07-17-2013, 02:45 PM
  2. Acramatic 2100
    By dmerrll in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2012, 10:41 AM
  3. Replies: 3
    Last Post: 03-07-2011, 04:50 PM
  4. Need Help, Acramatic 2100
    By acra2100 in forum Controller & Computer Solutions
    Last Post: 10-07-2009, 10:15 AM
  5. Acramatic 2100 G83
    By cnccalgary in forum MetalWork Discussion
    Last Post: 03-11-2009, 04:03 PM
