586,043 active members*
3,704 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > CMOS Battery Low after RTC Change
Results 1 to 6 of 6
    Sep 2007
    6
    Exclamation CMOS Battery Low after RTC Change
    Hello,
    Our Hurco BMC 30 suddenly reported "CMOS Battery Low" when we switched it on last month.
    I used the search for this forum and found out i had to put an external 3v cr2032 to the chip, which our local electrician did.
    i did cmos reset with the jumper9 but the problem still persists.
    we bought a new dallas chip (DS12887A) from hurco and STILL "CMOS Battery Low"
    i have no idea what could be the problem and hope someone can help me, thanks in advance!
    more info:
    -there is also a warning "CMOS Display Type Wrong"
    -after jumper cmos reset, the machine does NOT display CMOS Battery Low, but fails to find a boot device (which i guess is because the bios hdd settings are wrong)
    -bios setting changes are not saved
    -Ultimax 3 v1.63 Control
    Jun 2004
    511
    Re: CMOS Battery Low after RTC Change
    What control is this?
    Jun 2008
    71
    We are having the same issue with our BMC30, the power supply flaked out so we took one out of another machine and got the machine to start the boot but get a CMOS battery low warning and won't go past that. Going to follow this thread to see if we can get ours working too.
    Sep 2007
    6
    sorry double post
    Sep 2007
    6
    thanks for your answer,
    we also recently switched out the power supply with a new one from hurco.
    our machine is running on Ultimax 3 v1.63
    Jun 2008
    71
    Did you get your machine up? Also where is the battery located? I looked at the mother board and cant see it, unless its on the back side.
  1. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  2. Centroid M15 cmos battery low
    By Air Ride in forum Controller & Computer Solutions
    Last Post: 11-20-2013, 11:07 PM
  3. CMOS Battery
    By Holzwurm56 in forum Bridgeport / Hardinge Mills
    Last Post: 08-18-2012, 04:37 PM
  4. CMOS battery
    By APinSoFla in forum Milltronics
    Last Post: 02-15-2010, 04:25 PM
  5. External cmos battery?
    By MegaMoog in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2006, 01:51 AM
