586,069 active members*
3,690 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati T30 5-axis I/O
    Jun 2012
    125
    We have a Cincinnati T30 5-axis with a Acramatic 950 control. When I turn the machine on the alarm on the operator station says "NCA-ASL 30 XFMR OVRTP". My control rack apears to be fully booted and the DCI cards all look to be functioning. The IBA card has 2 lights that should not be on but I can't tell you how to clear them. The modules page on the operator station does not reflect the indications from the DCI cards. It appears that the control and the I/O are not talking to each other.
    Attached Thumbnails Attached Thumbnails imag0097.jpg   imag0095.jpg   phone-0130..jpg   imag0096.jpg
    Dec 2006
    584
    Re: Cincinnati T30 5-axis I/O
    If this is a new install, the machine may have had a step up or step down transformer. It may have had a over temp sensor in it that is not wired up. Look for two small wires ( 14 or 16 gage) coming from the transformer. If it has been running, look in the electrical prints and see what transformer the error code lists and what wires/input it goes with.
    Mike cncmachineservices (dot) com
    Sep 2008
    100
    What types of drive do you have? Indramat o siemens?
  1. cincinnati z axis notrdy
    By jarl85 in forum Cincinnati CNC
    Last Post: 02-05-2014, 10:53 PM
  2. Cincinnati Arrow 500 thinks it has 4th axis....
    By dreygata in forum Cincinnati CNC
    Last Post: 07-02-2012, 02:32 PM
  3. Cincinnati Hawk TC250 X-axis zero
    By bri581 in forum Cincinnati CNC
    Last Post: 12-10-2010, 11:18 AM
  4. Cincinnati 15VC Z-axis following error
    By jrice in forum Cincinnati CNC
    Last Post: 11-30-2010, 01:49 PM
  5. Cincinnati 5VC-750. Y-axis running away.
    By cnc1000 in forum Cincinnati CNC
    Last Post: 11-09-2010, 01:15 PM
