586,321 active members*
3,757 visitors online*
Results 1 to 8 of 8
    Apr 2009
    35
    K2CNC - Terrible Experience
    We purchased a 5' x 10' router last Dec. I was told we would receive it 30 days later...we got it four months later and it has yet to work. I have placed numerous phone calls and get either no response or they tell me they will get try to get it working remotely (unsuccessfully). I have asked repeatedly to have one of their staff come out and get this machine working ...I am getting the run around. This is 3/4 of a year without a working machine. We paid in full before delivery. I'm about ready to ship it back and ask for a full refund. I would not recommend this company. Customer service is terrible, can't comment on the machine because IT DOESN'T WORK.
    StuartC
    https://www.stuartgraphics.com/
    Apr 2004
    5740
    Re: K2CNC - Terrible Experience
    When you say it "doesn't work", what do you mean? Does it not power up, not move at all, not move correctly, quit prematurely, or what? Is it using Mach3 or some other control software? Are you trying to run it on your own computer, and if so, what sort of computer is that?
    Andrew Werby
    Website
    Apr 2009
    35
    It has powered up twice and blown electronic parts both times. We have replaced several electronic parts of the controller by K2's instruction. The last time, the gantry moved from one end to the other, froze and has not moved since. I am using the K2CNC controller running on the computer K2 supplied as part of the package.
    StuartC
    Mar 2012
    378
    I got a 14" X 25" machine from them about 10 years ago. It has been pretty reliable and I use it a good bit so it has paid for itself many times over. I plan to build a bigger machine with supported rails that will be more rigid soon. They are not very good when I call or email with questions. I sense an attitude from them of "We already got your money so you are not a priority".
    I would be furious if I bought a big expensive machine and had the problems you are having.
    If you can't get any resolution from them and need to get it up an working I would recommend a Smoothstepper board and Gecko drives. I realize that you paid for something that should work, but it might be a way to cut your losses from something that does you no good at all. Suing a company in another state is not an easy or inexpensive process unfortunately.
    Feb 2007
    966
    What type of drives are in the machine ? What type of motors ?
    Did just one axis blow ? Are the other axis still moving ? Is the software all setup properly . MORE INFO ....
    To be honest, just saying " it doesn't work" can be very irritating to a tech support department.
    Jun 2005
    1730
    StuartC,
    Did you guys get your machine fixed? Looks like K2CNC went out of business.
    Russ
    Oct 2015
    6
    Hmmm, sounds just like the runaround I was given last spring. Now that they are out of business, this makes perfect sense.
    Did you ever get your table running?
  1. My terrible experience with Burntables and my resolution
    By shiner2001 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-11-2016, 05:27 PM
  2. Ideas on why finish so terrible?
    By Otokoyama in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2014, 05:59 PM
  3. First try cutting bamboo plywood - looks terrible!
    By Enk1du in forum DIY CNC Router Table Machines
    Last Post: 02-25-2014, 09:03 PM
  4. 4th Axis – Results are terrible….
    By hkenuam in forum BobCad-Cam
    Last Post: 11-17-2010, 03:36 AM
  5. Terrible Air Force decision
    By 1964455 in forum Community Club House
    Last Post: 03-10-2008, 03:10 PM
