586,036 active members*
3,620 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Nozzle\Mixing tube just expires in 20 hours
Results 1 to 6 of 6
    Jul 2014
    Hello Friends...i am facing a unique problem from last 2 weeks...my nozzels expired just after in 10 to 20 working hours..i try different companies nozzels Roctec100 aswell...but they all damaged in a same way...even i change mixing chamber if its allignment were out ..but same problem ..please check pictures and help me how to fix it & where actuall fault is ...
    Thnx
    Qasim
    Jul 2010
    46
    Re: Nozzle\Mixing tube just expires in 20 hours
    Have you changed your orifice lately?
    Jul 2014
    alexhawker i can use every new nozzle with new orifice... but same result
    Jul 2010
    46
    Quote Originally Posted by qasimk View Post
    Hmm, I've never seen anything like that, but I wouldn't say I've seen a lot. What make/model is the machine?
    It almost looks like your mixing tube isn't being held in line with the high pressure stream. Is it possible to adjust it somehow on the head?
    Have you had any recent crashes that might explain the misalignment?
    I would try marking the mixing tubes after installing each fresh one, to see if the uneven wear you're seeing is always in the same place. This would help you figure out the direction of the misalignment.
    Sep 2013
    16
    What kind of pump, how much pressure are you trying to push through it. I see you mention Rotec 100? We don't use anything buy Rotec 500 nozzles, and typically see anywhere from 1-2 months of good use on a nozzle.
    Apr 2015
    Thnx
    Qasim
    Probably solved your problem by now I am guessing!
    My guesses would be the type of garnet you are using, extreme pressure from pump (unlikely), but my guess after garnet size would be the timing of events. If the event timing is off it will allow garnet to clog the mixing tube. Enough pressure will blow out the clog but also part of the mixing tube as well. At the end of each cycle allow enough time for the garnet feed to shut off, while still running water through the nozzle for a few seconds.
    I had a similar issue with two omax machines when I began to start playing with low pressure etching. Event timings were off, tubes were clogging. Fortunately enough before running high pressure through the tubes I corrected the issue. Easy fix on omax, don't know about other waterjet machines!
  1. Flow waterjet blowing out mixing tube
    By MarineMachinist in forum Waterjet General Topics
    Last Post: 09-15-2015, 08:01 AM
  2. FREE MASTERCAM Training for first 30 students (expires 8/31)
    By VTPROS in forum News Announcements
    Last Post: 08-19-2013, 11:18 PM
  3. New Chinese 8000-10000 hours lifespan Tube
    By oneeye in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 04-22-2010, 09:50 AM
  4. How can i find when my CATIA license expires?
    By bigalexe in forum Uncategorised CAD Discussion
    Last Post: 08-23-2008, 06:44 PM
  5. Waterjet mixing tubes (nozzle)
    By Tommy2Times in forum Waterjet General Topics
    Last Post: 03-07-2008, 04:49 AM
