Hello
I need 20 pairs of 2 =40 pieces of stainless steel 304 on 1mm thickness.
You can see the pdf file here with the pattern of cutting.
This is a decorative part for a wooden project i make with my wood cnc and i have used to work on metric system, so the metric dimensions in my PDF are more accurate.
In case the cost for laser cutting in stainless steel with one mirror surface is too expensive by using stainless steel with no mirror surface please inform me.
Thanks in front
Kosmas Evangelos
Heraklion Creta Greece
