586,104 active members*
3,449 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Spreadsheet to convert graph equation to Gcode
    Apr 2003
    416
    First post in a long time. Just got my cnc router dusted off and running again. Experimenting with cutting 3d shapes into wood.
    I used a spreadsheet (with a little VBA code) to generate the gcode from a formula: z=(cos(x)sin(y). The spreadsheet will export a Gcode file and a script file (to read into an Autocad drawing). The spreadsheet can be used with any xyz formula. You enter the range to cover and the increment to step. Click the calculate button and the files are written. I got the idea looking at the "QuickGraph" app on an ipad. Anyone interested in this let me know.
    Here is the pattern I cut into a piece of pine.
    Attachment 245014
    Here is a screen shot of the Autocad screen:
    Attachment 245016
    And here as a screen shot of the Spreadsheet:
    Attachment 245018
    Mar 2018
    15
    Re: Spreadsheet to convert graph equation to Gcode
    wjbzone what all Excel vba and formula spreadsheets and VB6 softwares you have about CNC and g-codes ?
    cheers!
    - - - Updated - - -
    cheers!
  1. I will pay for someone to convert STL to Gcode (mach3)
    By Davidodem in forum Want To Buy...Need help!
    Last Post: 07-20-2013, 07:32 AM
  2. How to Convert 3D Drawing DFX to GCode?
    By pa2012 in forum G-Code Programing
    Last Post: 06-07-2012, 04:52 PM
  3. Convert 3D animation to Gcode
    By druitre in forum Uncategorised CAD Discussion
    Last Post: 09-15-2011, 09:29 AM
  4. Convert Gcode units
    By NickAshton in forum G-Code Programing
    Last Post: 01-25-2009, 10:48 PM
  5. convert se to gcode
    By ata in forum G-Code Programing
    Last Post: 04-27-2007, 08:06 AM
