586,103 active members*
3,355 visitors online*
    Jul 2014
    FANUC o - m late start Problem
    I have ENSHU DT- VMC with Fanuc o-m. Recently in the morning when trying to turn the machine ON at the head unit it will not startup right away.The machine will not boot. No Display on CRT. We have to swich ON & OFF Mains several times. After half an hour to 45mins it starts booting and works fine. I have found no 24 v at display power in. Anyone have any idea as to why it won't turn on right away anymore?
    May 2014
    36
    Re: FANUC o - m late start Problem
    Ive got an O-MD control but im sure its almost the same .
    In the electrical cabinet you will have a smallish black box with the 2 green fuses on it .
    Thats a power supply of some sorts .
    When my screen wouldnt switch on i had to have that box repaired .
    I think it supplies power to the screen .
    Had mine repaired and all was good again .
    Not sure what was broken or faulty but if you good with electronics maybe you could figure something out in there .
    Jul 2014
    THANK YOU VERY MUCH Shottie. I have seen the power supply and will be opening it soon to find out any trouble in the pcb, may be a bad condensor.
  1. Another start up problem
    By blackbolt9 in forum Cincinnati CNC
    Last Post: 05-06-2011, 01:19 AM
  2. KM 3 start up problem
    By ndfan in forum HURCO
    Last Post: 09-23-2010, 04:52 PM
  3. Fanuc oma start up problem
    By monaro mike in forum Fanuc
    Last Post: 04-05-2010, 12:34 AM
  4. spindle start problem
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 05-03-2008, 03:04 PM
  5. Late 80's Hurco BMC 20 communication problem
    By tirebiter in forum DNC Problems and Solutions
    Last Post: 09-19-2006, 05:02 AM
