586,103 active members*
3,333 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > How to change round linear bearings
    Sep 2004
    12
    Hi
    My Thompson bearings are running rough. I`d like to change them. Has anyone installed new bearing in
    the aluminum housing. I am wondering how difficult the removable process will be. I will add blocking to the
    gantry and brace from the floor to support the machine. There is a 1 foot section of the 1 1/4 support
    shafting I can remove to remove the bearings from the machine. One thing I was hoping to remove the bearing
    without removing its aluminum support block. Do you think this is possible. I see a dowel pin. This looks like
    a problem.
    Sep 2004
    12
    Success with the bearing changeover.
    Hi all
    I was never happy with the shake I got on the z axis. I spoke with a application engineer at thompson.
    They mentioned that there were two types of bearing assemblies for the round shaft. One was made from
    plastic and the other was all steel and non-aligning. After removing one assembly from the machine I was
    certain the machine had the self-aligning versions. After the change to the new bearings the machine is
    much tighter. If I remember correctly the self-aligning version has 5 degrees of adjustment. This causes
    a looseness in the linear system. Which translates to a non rigid linear motion system and causes additional
    machining marks in the work piece.
    If I were making a new machine I would Not use a round linear motion system. I would buy the THK square
    rail version.
  1. Linear Carraige or Linear Motion Round Support Rails
    By newpatch in forum DIY CNC Router Table Machines
    Last Post: 03-09-2012, 12:36 AM
  2. Source for large qty of cheap linear ball bearings - round shaft
    By InspirationTool in forum Linear and Rotary Motion
    Last Post: 01-10-2007, 04:00 PM
  3. 20mm Round cradle for open thomson bearings
    By simso in forum Linear and Rotary Motion
    Last Post: 12-28-2006, 11:52 PM
  4. skate bearings versus linear bearings
    By paul langwade in forum Linear and Rotary Motion
    Last Post: 05-29-2006, 04:06 PM
  5. Linear bearings - round or square?
    By kerino in forum Linear and Rotary Motion
    Last Post: 02-24-2006, 03:56 PM
