586,260 active members*
3,002 visitors online*
Results 1 to 10 of 10
    Aug 2006
    Unhappy Fanuc 21-tb alarms
    It is a Harrisson Alpha 550
    Year 1996
    Serial no .A50085
    600 Lathe number A50085/027
    We can see alarms
    506 +x owertrawel
    507 -z owertrawel
    507 +z owertrawel
    Every time we look at alarm history
    at every start
    On the display
    Even if we clear the history list.
    And the lathe will not start.
    Hello I get alarm red led number 2 on the cnc moudule
    Can anyone tell me the meanig of this.
    Jan 2006
    4396
    Please post the Machine Tool Manufacturer and year so someone can better assist you.
    There are a lot of very bright people here that can help.
    Welcome to The Zone :cheers:
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    24221
    pdf.
    Al.
    Attached Files Attached Files
    Albert E.
    Sep 2008
    Unhappy Electromecanik - Low control power voltage alarm LV
    Hello All, I have a Tsugami FMA3 with Fanuc Control milling machine with a little problem, last time I turned it ON the Y axis servo drive had an ALARM 2 code (Low control power voltage alarm LV). I took the driver out and everything looks just fine but the ALARM doesnt get away. I tried changing the command cable to the X axis but the ALARM remains in the same driver. Does anyone knows if there is a way to fix this problem?
    Mar 2007
    I have the same problem on a Mori Seiki Frontier L. Was a solution ever found?
    Dec 2008
    239
    SRAM LOST
    The SRAM data of the machine is gone relaod The parameters than u can get the original screen
    Feb 2009
    6028
    Quote Originally Posted by mlbieker View Post
    What problem. there are more than one listed here. Frontier L what BTW. A L2 I would assume, witch is a SL25, just newer control. The L1 was a small machine like a AL2
    Oct 2008
    FANUC 21-TB ALARM 1020 MOTOR OVERLOAD
    THE DRIVE UNIT IS NOT ALARM(--,0)
    Hello, I have bought a VMC with Controller Fanuc O-M the machine is Korean make of year 1993-94. When we started the machine some of the MOVs from the Servo Amplifiers PCB and Main power supply PCB so we changed the MOVs. Now the machine is started and the screen is Showing two ALARMs
    i.e
    1) 1020 - -O.T
    2) 403 - Servo Alarm (VRDY off)
    Please some one tell how to reset these alarms.
    Dec 2012
    I used to have problem with the same alarm many years ago, what I did is check and rearrange the power connection then restart the machine. I applied this for Robodrill
    Sent from my Dell Venue using Tapatalk 2
