Hello everyone. Sorry if im posting in the wrong section coz im new here and I need help badly in tunning stepper motor running with mach3. I started this project as a 3 axis mini cnc milling. I will post pictures if I succeed.
I constructed its bed first, that is the Yaxis and decided to try with mach3 before constructing the other axis. This is when my problem started, in motor tuning 'steps per' I entered 800, Calculation of steps per unit setting: 200steps x20 microsteps ÷ 5mm ball screw pitch = 800
please correct me if im wrong.
The slide moved very slowly and I measured its movement with mitutoyo depth vernier,if i moved it 1mm it moved 0.300 mm (or something close to it)
Now here is the problem, if I try to calibrate the movement with mach3 steps calibration where it moves the axis and later asks how much did it move, that figure is more than 4 times my calculation I.e. 800 and never in round figure like 3324.221242. Every time i auto calibrate the axis, the steps per unit keeps on changing as it never moves a fix amount, sometimes it will go 51.2 when moved 50mm or 99.5 when moved 100mm or go overtravel 3 or 4mm when i enter y0.0 in MDI mode.
Some machine specs,
Mach3 running P4 pc with XP3 SP3, on board Parallel port
Chinese 3axis controller from ebay
Stepper motor 1.8 deg 200 steps 4 lead 18.9 Kg cm
3a stepper driver with microstepping from1/2 to 1/64
Hiwin 5 mm pitch ballscrew with nut
Nachi 7201 Angular contact bearings
with locking checknuts on back.
When I use low microsteps like1/2 the motor starts vibrating, makes a whining sound and doesnt rotate at all so I use 1/20 microstep setting. There is no physical backlash and slide moves freely when the screw is rotated by hand, so im stuck as I dnt know where the problem is.If it is a missing steps problem how do i check it and what is the remedy to correct it.
Thanks in advance.
