586,071 active members*
4,014 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil X5 Z axis limit switch location
Results 1 to 7 of 7
    Apr 2011
    14
    My X5 is always miss setting the Z Axis Home position (Reff All) - it can find any number of different positions. Does anyone know where the switch is located...the tech drawings never mention it. I'm thinking it may be loose?
    (using Mach3)
    Thanks in advance.
    Greg.
    Jun 2007
    3757
    Re: Syil X5 Z axis limit switch location
    Try setting debounce to a bigger figure. Probably noise on switch lead.
    My SX3 does that, but I know it is dirt and stuff on optical interrupter, so I just give it a blast of air if it does not get to the taped mark.
    Apr 2011
    14
    Smile Re: Syil X5 Z axis limit switch location
    Hi Neilw20, I will try it out > current setting was 4, new setting 100. I'd still like to know where I can access the switch - it's not visible from the front of the machine.
    Jun 2007
    3757
    4 would be next to useless, bump it up to say 125 ~~ that's 10mS. You might have dust in optos, like me.
    Where in Aus are you? I am in Melbourne.
    Apr 2011
    14
    If any one knows where the X5 Z limit switch is physically located I would still like to know.
    Hi Neilw20, I’m in Sydney, Kings Langley.
    I’m a watchmaker, hand making a watch with the view to starting a company. The Syil X5 seemed ‘fit for purpose’ as a CNC solution because I am making very small parts. I work full time so the project is taking forever.
    I use Mach3 with the Smoothstepper interface; software crashes seem to be a real plague with this setup.
    Originally I tried to get the X5 with servo's but the dealer here said that Syil would not supply them....I think the extra cost would have been worth while. I built a 5th Axis (which stretched the capability of the X5) but the results are disappointing mostly due to my poor design specs.
    Any way...
    Apr 2011
    14
    I've just tried the debounce setting (125) and there is no change.
    Just to provide more of an explanation; if I move the Y Axis away from Home then Ref All, it will move the table until it finds the Y Axis limit switch. If I do the same for the Z Axis it will decide that Home is within about 10mm from its current location, it will not move the head until it finds the Z Axis limit switch.
    Jun 2007
    3757
    Is that a ethernet smoothstepper or USB?
    Some versions of Mach3 don't work well with Smoothstepper.
    SS recommend ...050 Mach3. Is it running out of data? PC might be a problem. Laptop. Almost certainly a problem.
    Why...
    Read all of this to instill confidence in my comments!!
    Time
  1. Setting Home Location, Table Travel, and Home Switch Location in Stepconf
    By northbear in forum LinuxCNC (formerly EMC2)
    Last Post: 08-25-2013, 05:07 AM
  2. 1996 Sabre 1250 - Y axis TPA switch location
    By jaredsparks in forum Cincinnati CNC
    Last Post: 12-05-2012, 03:53 AM
  3. Syil sx3 Z axis opticl switch wiring
    By Mr Miller in forum Syil Products
    Last Post: 11-20-2012, 01:39 PM
  4. Replies: 6
    Last Post: 09-20-2011, 12:46 PM
  5. syil xp5 trigger limit switch
    By Vik in forum Syil Products
    Last Post: 10-29-2010, 07:05 AM
