586,307 active members*
3,459 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Need Help with Rhino Cam
Results 1 to 3 of 3
    Oct 2011
    How to change the start and end point of a tool path in Rhino cam?
    Oct 2005
    169
    Re: Need Help with Rhino Cam
    If you use a predefined region you can change the start point and direction
    Attachment 243970
    I have also found Rhinocam by default seems to choose the start point and direction based on the order the entities were created.
    If you type "DIR" in the Rhino command line, You can change the direction of the entity.
    Mar 2010
    99
    Also you can use Rhino CrvSeam command to move start point.
    Was:
    Attachment 249500
    now:
  1. Rhino Video Tutorial - Create a Diamond Solid in Rhino
    By Robert Schutz in forum Rhino 3D
    Last Post: 06-02-2008, 07:58 PM
  2. Rhino on MAC OS X
    Last Post: 06-08-2007, 07:01 PM
  3. Replies: 0
    Last Post: 11-13-2006, 08:55 AM
  4. The Rhino Pen: A Gallery of Rhino Drawings
    By BobWarfield in forum Rhino 3D
    Last Post: 06-08-2006, 05:19 PM
  5. Has anyone used a Rhino Controller (Not Rhino CAD)
    By runnoahrun in forum CNC Machine Related Electronics
    Last Post: 10-31-2005, 11:42 PM
