586,103 active members*
3,402 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > CL-2MD - 5 Axis Make it to work
    Hi guyz,
    I'm in need of your help. The factory where I started to work owns this machine CL-2MD - 5 Axis | cmie.ro . They brought it from china years ago and have never worked with 5 axis. Now they want me to make it work. I'm totally lost, because I have no experience with it, I've only worked with 3 axis machines. I know it sounds stupid but could anyone give me a starting point? I dont even know which software to use and how to input that machine definitions. I tried SprutCam and it looks nice (SprutCAM — CAM Software Solution for Your Manufacturing Needs) but couldn't go far...
    Please guide me guyz I'm in a trouble
    thnx
    Feb 2009
    2143
    Re: CL-2MD - 5 Axis Make it to work
    You aren't in too much trouble unless you told them you are a 5-axis guru - clearly they don't know how to use it either! Step one I would think is to settle on a CAM package and have that supplier get you a good post processor. Without those pieces, the machine can't be expected to do "anything". 5-axis CAM is complex and expensive, and the pool of resources is not very large! I know a few packages that CAN work: MasterCam, BobCad, SprutCam, GibbsCam. I am sure there are more. Make sure you get a package that will offer you STRONG learning support because your learning curve will be HUGE for this task. Good luck, and don't put too much pressure on yourself - they want you to feel it is "your fault" for not knowing answers that they don't know theyselves, and your management likely has no idea how difficult learning 5-axis programming is going to be!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    You can get your answer if you know the details of 5 axis cnc, and I think this can help you..
    http://cncmachinetools.org/5-axis-cn...ing-operation/
    Thnx guys for quick reply, at least now I know the weight of task. I think I'll stick to SprutCam. Thnx for resources, I'll try my best
    Mar 2023
    someone can help about this machine?
  1. Work Available: Make me a Stamp
    By Johnniewalker in forum North America RFQ's
    Last Post: 04-27-2013, 06:10 PM
  2. Need someone to make my designs work on my CNC
    By jimmy5 in forum Musical Instrument Design and Construction
    Last Post: 06-18-2012, 03:53 AM
  3. What to make when there is no work to do?
    By Jim Estes in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 02-19-2010, 11:27 AM
  4. Anybody here using Cimcool and can make it work?
    By phantomcow2 in forum MetalWork Discussion
    Last Post: 08-30-2006, 05:08 PM
  5. Trying to make this work- G code
    By WOODKNACK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2003, 06:00 PM
