586,036 active members*
3,514 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Does anyone need service manuals for popular Doosan Machines?
Page 2 of 9 1234
Results 21 to 40 of 179
  1. #21
    Jun 2011
    124
    Re: Does anyone need service manuals for popular Doosan Machines?
    Hello! Any and all for a Mynx please! If you need to, private message me! Thanks a million!
  2. #22
    Feb 2013
    788
    "Mynx" is an entire series, and has been made for many years. Designs and functions have changed over the years, as well.
    I will attach the most popular ones...
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  3. #23
    Feb 2013
    788
    Mynx 650 Service manuals for Installation...
    Attached Thumbnails Attached Thumbnails Mynx650_AV63ISE98.pdf
  4. #24
    Feb 2013
    788
    Mynx 650 Service manual for Mechanical...
    Attached Thumbnails Attached Thumbnails Mynx650_AV63MTE02(Machine).pdf
  5. #25
    Feb 2013
    788
    Mynx 650 Service manual for Alarms/Electrical...
    Attached Thumbnails Attached Thumbnails Mynx650_AV63MTE02(Alarm)_100200.pdf
  6. #26
    Feb 2013
    788
    Mynx 6500 Service manual for Mechanical...
    Attached Thumbnails Attached Thumbnails Mynx6500_M6500MTE4C(Machine).pdf
  7. #27
    Feb 2013
    788
    Mynx 6500 Service manual for Alarms/Electrical...
    Attached Thumbnails Attached Thumbnails Mynx6500_M6500ALE0C(Alam).pdf
  8. #28
    Jul 2009
    86
    Would you happen to have a manual, or section of one, that describes in detail how to align the headstock, turret and tailstock?
    Also specifically how to reset the center-line after preforming such an alignment?
    Model: Lynx 220 LC
    Year: 2011 – Sept.
    Serial#: ML0022-005385
    Colton.
  9. #29
    Feb 2013
    788
    This Lynx 220 installation manual has the geometry adjustments near the end.
  10. #30
    Dec 2012
    12
    Excellent information ! Do you have the same manual for a Lynx 220 LSYC ?
    Thank you.
  11. #31
    Feb 2013
    788
    CPInc,
    While it would, eventually, be beneficial to have a version for every style of each machine, we are in our infancy with regards to our documentation.
    Our focus, currently, is on getting versions of service manuals that were do not have.
    Someday we might be caught up enough to have manuals specific to individual product, and not limited to its base version.
    If you have specific sections that you would like that deal with the sub-spindle or Y-axis geometry, I might be able to find comparable sections from other model's manuals.
  12. #32
    Dec 2012
    12
    Thanks for checking it out, I know the "Y" axis Lynx is a newer release for Doosan. Currently I am not having any issues with the machine, I just like to have the information if something does go wrong. I appreciate you getting back to me.
  13. #33
    Feb 2013
    788
    Anytime.
    If you have any questions, you may call Doosan Service 24/7 at 888-936-6726 (888)-9-DOOSAN
    Or dial directly to my extension 8:30-5:30 Easterntime at 973-618-2461
    ...or call my cell 24/7 at 973-803-9479
    Let me know if we may be of service.
  14. #34
    Feb 2013
    788
    A manual for Teardown and rebuild of a Puma 240MS
    Not sections of this manual can be used for other slant-bed models
    i.e. The live tooling in this manual is "rear-mount" ...as are the early TT1800's and 2500's, TL2500's Puma 2500, others...
    Attached Thumbnails Attached Thumbnails P24MMTE87(mechanics).pdf
  15. #35
    Jul 2010
    11
    We have a Puma 2014 400 M with a Fanuc I-series and a 2014 lynx 300M. Do you have service instructions for spindle and turret alignment. also do you have parameters for the turret position so I can realign the x-axis to the proper position. Currently the only way I know to realign the turret is to bring the x to zero and adjust until its in the proper position then home it then bring it down the amount it was off, And finally I would turn parameter 1815 APZ from 1 to 0 then back to 1 and restart. This works but it constantly changes my home position.
  16. #36
    Feb 2013
    788
    Quote Originally Posted by mavruk View Post
    The 400M and 300M (both having milling) align in the same way as the 240M(S)
    To align the spindle and turret, you should be able to use the 240MS manual and instructions that are here, in combination with section 5 (or E, depending if the sections are numbered or lettered) of the Instruction Manual that shipped with the machine.
    Start by checking the Main Spindle for taper, then the Sub spindle (or tailstock, if applicable)
    Check that they center-match to within 0.0002" or less.
    Align all three planes of the turret to square and position.
    Then set home by centering X at spindle center (<0.0002") and, using relative position reset, move X up to the amount in parameter 1240, and then setting 1815.4 1->0->1
    If you have put your X-axis 0 back onto the spindle's centerline, then the home position alteration should not matter as home is STILL the 1240 position from centerline.
  17. #37
    Feb 2013
    788
    DNM500 Maintenance Manual
    Attached Thumbnails Attached Thumbnails DNM500_DNM500MTE0A(Machine).pdf
  18. #38
    Jan 2016
    10
    I would appreciate it immensely make available machining center files HP4000,
    I am of the maintenance area and I have great difficulty in solving problems of these machines
  19. #39
    Feb 2013
    788
    Quote Originally Posted by marcelo_maint View Post
    I will post any relevant files upon my return to the office,on Tuesday.
  20. #40
    Jan 2016
    10
    THANK YOU VERY MUCH
Page 2 of 9 1234
  1. Accurpress Service Manuals
    By FusionMachine in forum Bending, Forging, Extrusion...
    Last Post: 11-12-2012, 12:23 AM
  2. Doosan Daewoo ForkLift Service Manual
    By VikingCAD13 in forum Daewoo/Doosan
    Last Post: 07-02-2012, 06:52 PM
  3. Service manuals
    By sixthearl in forum Haas Mills
    Last Post: 10-11-2009, 08:26 AM
  4. Maintenance or service manuals
    By bigbobomb in forum Fanuc
    Last Post: 11-13-2008, 02:32 AM
  5. Hurco service manuals required
    By Graham S in forum Waterjet General Topics
    Last Post: 12-12-2005, 03:15 AM
