586,379 active members*
2,629 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Does anyone need service manuals for popular Doosan Machines?
Page 5 of 9 34567
Results 81 to 100 of 179
  1. #81
    Feb 2013
    788
    Re: Maintenance Manual Lynx 220LM
    The Lynx 220LM is very similar to the Puma 240M (which is posted in this forum)
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  2. #82
    Dec 2005
    68
    Darryl
    do you have any docs on how to replace spindle bearings on a puma 200B
    and besides the bearings and the oring what other parts are recommended to replace , the collar labyrinth has to be replaced .?
  3. #83
    Dec 2005
    68
    Re: Does anyone need service manuals for popular Doosan Machines?
    I need service manuals for DAEWOO PUMA 200B
  4. #84
    Jul 2003
    16
    Do you have one for HP4000?
  5. #85
    Feb 2013
    788
    Quote Originally Posted by DANIEL HALL View Post
    Darryl
    If the labyrinth sets the preload on a tapered roller bearing AND it needs to be made larger to accommodate the new bearing's requirements, then it does need to be replaced. If needing to be altered to smaller, then "no"
    For the instructions: I have a manual for a similar machine already posted to this thread...
    page back to my post in this thread on 4-24-2015 at 3:13pm
    Use that manual, but note: the instructions and procedures are the same, but the parts are not. also...NO DOOSAN MANUAL WILL EVER TELL YOU THE PROPRIETARY PRELOAD RATIO. (When we did, customer screw ups got us sued. Preload too little makes "sloppy", preload too much makes premature bearing failure) This ensures that there is actual knowledge of bearings and their assembly, to have a repair be done correctly.
  6. #86
    Feb 2013
    788
    This machine is older than the manuals available beyond those shipped with the machine, sorry.
  7. #87
    Feb 2013
    788
    Quote Originally Posted by kbarratt View Post
    As pointed out on 01-19-2016 at 09:19am
    The HP 4000 is an older machine.
    I do have manuals for an HP 5100.
    Procedures are similar, but part numbers are different.
    I then posted a mechanical, electrical, and 2 troubleshooting manuals. Please refer to those post, earlier in this same thread.
  8. #88
    Jul 2017
    50
    Hello, our shop has a Puma MX2500LST.
    The milling spindle shaft cracked in the taper and in preparation for replacing the spindle, I was wondering if there is anything special that needed to be done to set the spindle orientation so both the curvic coupling and tool changer work without issue. Nothing is mentioned in my manuals.
    Thank you.
  9. #89
    Jun 2005
    32
    Any chance you can help with one information - does all Lynx 200 - 220 machines with out the patrol light , have the needed PLC ladder information to support the working of the lamps?
    The question is , does on all machines if the light is missing , only is missing the relay and the light , or does changes need to be implemented in the PLC program to make lights work if the machine did not have it when it shipped?
    ps. Any chance to get electrical diagram for LYNX 200A and B ?
  10. #90
    Feb 2013
    788
    To best tell you this:
    What is the machine's serial number? (found on the placard, located near the main power switch)
    What is the Electrical Hardware version? (found on the placard, located near the main power switch)
    What is the ladder version?
    Press the <SYSTEM> hard key
    Press the <PMC> softkey (depending on Fanuc model)
    Press the <PMCPRM> or <PMCCONFIG> (depending on Fanuc model)
    Press the <TITLE> softkey
    There is a field: PROGRAM DRAWING NUMBER (it is in the middle of the page)
    It contains a LONG alphanumeric sequence, separated by a comma or colon...and then another alphanumeric sequence
    I need the WHOLE code...everything in that field.
    From this information, I can see why the machine does anything and everything related to IO
  11. #91
    Jul 2018
    8
    Quote Originally Posted by dhardt View Post
    At Doosan, we have a wide variety of Installation Manuals, Service Manuals, Alarm Manuals, and Technical Documents that simplify the troubleshooting, diagnosing, and repair of our machines.
    These manuals are available to the general public.
    There are way too many to post them all here... (though, if enough people request a specific manual, I can post some of the smaller ones...larger ones will exceed this site's limitations)
    The attached screen capture shows a minuscule sampling of the available documentation.
    Hello Sir, can you share for Doosan dooturn 3 mchine
    Sent from my Redmi Note 5 using Tapatalk
  12. #92
    Feb 2013
    788
    Quote Originally Posted by Yomauindia View Post
    There are no Service Manuals for the MechaTec versions of old Doosan products, sorry.
  13. #93
    Apr 2012
    Hi Darryl
    I am a TAFE Teacher in Sydney
    I have a Doosan Lynx300M
    If you have a manual. Please post one.
    Also any useful training material regarding this machine would be appreciated
    Dave
  14. #94
    Feb 2013
    788
    Other than the one's sold as actual parts, the only manual I have for a Lynx is the Installation Manual. (Attached)
  15. #95
    DHardt,
    We are in need of any/all manuals for Doosan S310N (Serial number LSA1226). Right now, we have only the electrical manual and Fanuc controller manual for this machine.
    Local dealer tells us the manuals are no longer available for sell.
    I know the machine is old but I hope you can help getting manuals in any way.
    Regards,
    Louis Gauthier
  16. #96
    May 2015
    Hi , I'm also looking for a manual for
    Daewoo DMV3016L for info on machine teardown for a spindle removal/installation.
    Thanks, Cliff
  17. #97
    Sep 2018
    Hi I was wondering if I could get ANY information you have on a Doosan HP4000II? anything would be greatly appreciated!
    Thanks!
  18. #98
    May 2016
    526
    Hi D Hardt
    Do you have the programming manual for a Lynx 220LMS
    We have the others but are missing this
  19. #99
    Mar 2018
    4
    Hello i need doosan puma3100ly manual.
    I need to remove morse center and i m not sure how.
  20. #100
    Feb 2013
    788
    Quote Originally Posted by MetaldesignSLO View Post
    This is not something that requires a manual, so it is not in any...
    There is a spanner nut between the Quill and the thrust piston.
    On a machine with a Dead Center, the spanner is mounted on the quill and needs to be turned to go toward the thrust piston to push the quill out, off of its face.
    On a machine with a Live Center, the spanner is mounted on the Thrust piston and needs to be turned to go toward the quill to push the quill out, off of its back.
Page 5 of 9 34567
  1. Accurpress Service Manuals
    By FusionMachine in forum Bending, Forging, Extrusion...
    Last Post: 11-12-2012, 12:23 AM
  2. Doosan Daewoo ForkLift Service Manual
    By VikingCAD13 in forum Daewoo/Doosan
    Last Post: 07-02-2012, 06:52 PM
  3. Service manuals
    By sixthearl in forum Haas Mills
    Last Post: 10-11-2009, 08:26 AM
  4. Maintenance or service manuals
    By bigbobomb in forum Fanuc
    Last Post: 11-13-2008, 02:32 AM
  5. Hurco service manuals required
    By Graham S in forum Waterjet General Topics
    Last Post: 12-12-2005, 03:15 AM
