Originally Posted by
LongIslandWood
Thanks for the replies...
Are all the squares actually squares? Meaning are both legs the same size?
Yes
Did you actually check the move distance of each axis? Its pretty easy to do in mach 3
No, can you tell me how to do this? Or show me a place that explains it? Thanks
Did you put loctite on the jam screw for everything?
Yes I used loctite on almost everything
Were these cuts a single full depth profile cut or multi, if multi were the sides stair stepped.
They were a single full depth cut in 1/2" plywood with an amana 1/4" compression bit
How fast were you cutting them feed rate and DOC?
35 imp conventional
Thanks again, I'm going to do some trouble shooting tonight or tomorrow
