I was planning on buying the kit from MassMind, they seem to be a pretty decent source (also provide SLAm and Linistepper drivers).
Your advice on the acme screws is interesting. If I do that, do I need anti-backlash nuts?
[Not really. Anti-backlash nuts are spring-loaded against one side of the screw threads. That works okay until your cutting forces overpower the spring, at which point all the backlash is back, somewhat unpredictably. As long as your nuts fit the screw pretty well, backlash shouldn't be a big issue, at least for most things you're likely to be making with this machine.]
So if I end up with a 2' x 3' machine or probably something smaller, does your advice on the ballscrews still stand? And will I need to switch to a moving gantry with 1 or 2 screws?
[Yes, you still are better off with a good acme than a cheap ballscrew. In general, moving-table machines are more rigid than moving-gantry ones. Their major disadvantage is that they take up a bigger footprint. It's good to run the table on 2 screws rather than one; that avoids the "stuck drawer effect" when the table racks to one side or another. But this takes another screw, another driver, and another motor, slaved to the other X axis motor.]
There are 2 induction levels of the 270 oz-in motors, and I'm going with the lower one ( I think it was 1.6mH).
[That should be okay.]
Sorry about forgetting the frame, it's primarily going to be 2"x2" extrusion.
[If you go with a bigger machine, you might want to use beefier extrusions, especially in places where they aren't supported.]
In the way of a shop, I have my school's lab, which should have a router (I don't know its specs, I heard about it back in May when I barely knew what a router was). It will also definitely have a bandsaw that can cut aluminum (no more hacksawing!), 3D printer(s), I believe a drill press, possibly a table saw (don't think I'll need that).
[Actually, if you're making straight cuts, a table saw can do a better job on aluminum than a bandsaw. You need to use a blade with a lot of carbide teeth that have a negative rake (they tilt back a little, rather than forward). Blades like that are also good for plastics. But it's good to hear that you've got a shop of some sort; I thought the schools had mostly closed theirs down. The drill press will be the main tool you'll be using, though; you probably won't need the router. Laying out the hole locations for motor mounts, etc. is going to be the tricky part of this. Use blue DyKem fluid
Dykem 80300 Steel Blue Layout Fluid, Brush-in-Cap (4oz): Amazon.com: Industrial & Scientific on your aluminum parts so that you can see your scribed marks, and be sure to center-punch your hole locations before drilling them.]
I'm also part of FIRST robotics, and have some connections to teams with well-equipped labs--my team mentor will also know more people.
Thanks for the advice! This is really helping me out.
Matthew
