586,105 active members*
3,313 visitors online*
Results 1 to 8 of 8
    May 2014
    8
    ER20 spindle help
    I'm looking to get a ER20 spindle but I'm not sure about air or water cooled. can anyone tell me what the difference is between the two?
    Re: ER20 spindle help
    One is cooled by air, and one is cooled by water
    Air cooled are louder.
    Air cooled may have a lower max rpm (18,000 vs 24,000 for water cooled).
    At lower rpm, air cooled may run hotter, and may not be able to run continuously for as long as water cooled.
    Air cooled is easier to set up, as you don't need a water reservoir, tubing or pump.
    May 2014
    8
    this is the spindle I'm looking at from eBay (china)
    CNC 2 2KW Spindle Motor Frequency Inverter Mount ER20 Collet Water Pump | eBay
    any thoughts on the setup?
    thanks
    Not really. All the 2.2kw water cooled spindles and VFD's are pretty much the same, regardless of who you buy them from. Unless you have previous experience with one from that vendor, you really don't know what you're getting. The good news is that the majority of those spindles are good, but every now and then someone gets a bad one. You're always rolling the dice a little when you buy direct from China.
    May 2014
    8
    can i run antifreeze though the spindle without harming it?
    thanks for your help.
    Nov 2013
    9
    I'm using a 2.2KW ER20 water cooled spindle on my router... for cooling I am running a cheap ~$20 pump from Aliexpress pumping water from a 2 liter milk bottle, no radiator. I am yet to have it running for more then 1/2 an hour at a time but so far it is working great. Not the prettiest solution but it works. Only complication was finding the right fittings as the pump fittings weren't as described on Aliexpress. 120mm or 140mm radiators + fans for computer water cooling can also be picked up pretty cheap second hand and should provide ample cooling.
    May 2014
    8
    Will I harm the spindle if i use a pond pump with antifreeze? i don't know if the spindle will handle the water pressure of the pump or if the seals are good for antifreeze
    thanks
    Jan 2008
    940
    That spindle comes with a pump and most will let you run Antifreeze in them. I would say to try RV antifreeze though that was what they told m to run on my laser.
  1. ER20 High Speed Spindle
    By pakirk in forum MetalWork Discussion
    Last Post: 06-01-2012, 03:22 AM
  2. Changing ER16 to ER20
    By bananafish in forum Chinese Machines
    Last Post: 10-21-2010, 07:18 AM
  3. ER20 collets
    By p38nut in forum CNC Tooling
    Last Post: 08-18-2010, 03:33 PM
  4. ER20 Collets
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 07-21-2010, 10:28 PM
  5. ER20 to ER50 adaptor?
    By 15mgtar in forum Mechanical Calculations/Engineering Design
    Last Post: 03-04-2010, 05:57 AM
