We've put around £1000 into this CNC in total. Some of the parts were given to us by another hobbyist (no doubt a member of this forum) who were moving house and didn't have space for his CNC equipment anymore.
The frame is made from box steel welded together, it's very rigid. The MDF parts were made just to be able to CNC the parts again in aluminium later. The MDF isn't pretty but it will do for now! The router is fixed using a metal band and a rubber mat... for now anyway, the plan is to CNC that part too.
For now the only bit we have is a 1/8th end mill which apparently is supposed to be used for drilling, although we have been using it for everything until we can get some more collets and ball mill bits etc. (Still haven't figured out exactly what type of bit is used for what yet, some advice would be appreciated).
The router is a Kress FME 1050 which is a pretty powerful router and good enough for what we need. The plan is to wire that up to the relay on the controller.
With the testing we done, it seemed to be accurate to within 0.5mm on the X and Y, but the Z seems to be slightly out. the MDF parts dont help and there is some springyness to it.
We're using MACH3, and CAMBAM trial to do some test cutting. My brother is good with solidworks and autoCAD, so when we figure out how to setup CAMBAM to cut models from those programs, we will have a test with those too.
