586,103 active members*
3,719 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > can not run rhino cam "cant convert centimeters to millimeters"
    Aug 2014
    some one could tell which is the solution to this kind of problem? i cant run rhino cam, it is instaled with rhino 5 but when i run rhino 5, rhino cam just launches a message telling "cant convert centimeters to millimeters" then it just closses, is because some driver i dont have? is the install source corrupted? have you dealt with this kind of problem??
    i ve seen some bad comentaries about rhino cam, is it good? or power mill is better?? if so, some one knows where can i find power mill tutorials??
    Apr 2004
    5737
    Re: can not run rhino cam "cant convert centimeters to millimeters"
    This doesn't sound like an issue with RhinoCAM, but a problem with your Rhino installation or the way you're using it. Are you making your model in centimeters? Try going into Tools/options/units and changing that to millimeters. Usually, when Rhino starts up, it gives you the option of what template to choose - whether you want to draw in feet, inches, millimeters, whatever. Choose millimeters, if that's what you want to use. That dialogue should come up first, before RhinoCAM loads.
    RhinoCAM is a good program, and if you're having a problem (and if this advice doesn't fix it) it also comes with excellent tech support. Give Mecsoft a call and they'll walk you through a step-by-step solution. They can do this on your computer remotely, so you can see what they're doing and learn how to deal with the issue.
    Andrew Werby
    Website
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. Is a "coordinate table" usable for a cnc convert
    By Sky-high-11 in forum Stepper Motors / Drives
    Last Post: 05-11-2009, 02:38 AM
  3. Is a "coordinate table" usable for a cnc convert
    By Sky-high-11 in forum DIY CNC Router Table Machines
    Last Post: 05-10-2009, 11:36 PM
  4. Rhino equivelent to Autosketch 5 "symbols"
    By CurtisU in forum Rhino 3D
    Last Post: 05-02-2008, 02:47 PM
  5. Replies: 2
    Last Post: 01-25-2005, 05:26 PM
