586,096 active members*
3,732 visitors online*
    Jul 2003
    92
    My binder clip hold-downs
    My little CNC router is a K2 prototype. The maximum travel is approx. 10.75" (X and Y).
    Seeing as sheet goods come in multiples of square feet, I figured I'd come up with a method for clamping one-foot square pieces to the table, and this is what I came up with.
    It is a 3/4" thick piece of BB plywood. I reduced the thickness to 1/8" around the perimeter (about 3/4" into the board).
    Now I can place a thin waste board along with my workpiece on top, and use approx. twelve binder clips to hold everything in place.
    It is remarkably secure, plenty snug for routing. Using the largest binder clips I can accommodate materials up to 3/4" thick, which is about as thick as I go.
    This won't work when I'm routing larger pieces, I have other hold-down clamps I've made for that purpose. But I expect I'll be using binder clips for most of the work I do.
    BTW, the photos show a previously machined piece, to show how it works.
    Thanks for looking!
    May 2010
    41
    Re: My binder clip hold-downs
    Nice idea with the binder clips!!
    KL-4530 CNC, KL-6060, 5 3D printers, CNC Fusion Converted LMS Milling Machine, 60w Laser Cutter
    Jan 2006
    107
    cool easy idea! Thanks
    Jul 2003
    92
    Seeing as this thread was revived, I'll note that this method has worked very well and I've even found 12" square pieces of cardboard at Amazon which I can use as a spoil or backer. It isn't for everything, but for some projects it is great.
  1. Clamps or Hold-Downs
    By larbabe in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-20-2013, 09:15 AM
  2. Hold-downs
    By IQChallenged in forum News Announcements
    Last Post: 01-23-2010, 02:25 AM
  3. New T Hold downs installed
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2008, 07:57 PM
  4. Wet hold downs
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 12-18-2004, 07:20 AM
