587,043 active members*
3,218 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    keyboard hacking
    ive just got done ripping apart a keybourd to see if i can connect switches to the hot keys , turns out its a simple board with two terminals ,one terminal has 8 connections the other has 20 , so i took a wire connected it to one connection in one terminal then connected it to a connector in the other terminal ,with notepad on and ready to recieve info i kept trying different connections and had results most of the time ,so now its a matter of figuring out the complete matrix and i should be able to make a deadly control panel using one thru the usb port ,
    has anyone done this yet ,and or have any info which may make this easier to figure the combinations
    curt
    Jul 2005
    442
    How about using a USB keypad?
    Aaron
    i ve got one of those but not enough keys for what i'd like
    http://arcadecontrols.com/arcade_input.shtml#Keyhook
    these guys have a piece of software that shows what the key is supposed to be while i connect each different combination , this is too easy , i'll be able to use toggle switches (i hate push buttons) to create a customized control panel for my lil router table ,keyboards are a dime a dozen , its something ive thought about for some time now and finally decided to investigate this , glad i did ,
    Aug 2005
    157
    Here might be some more useful info:
    http://www.extremetech.com/article2/...1610432,00.asp
    http://www.dribin.org/dave/keyboard/html/
    As noted in the one article, there is a limit to how many keys can be pressed at one time.
    *If you use toggle switches you cannot connect more than that number (6 I think) at one time.*
    More than that and you will need to set up the software to "toggle" each time you press a key.
    Also you will generaly need to use diodes with multiple switches.
    Aug 2005
    157
    Here is another good one that has some example key matrix tables that might match yours if you are real lucky.
    Mar 2004
    75
    Feb 2005
    921
    I made something simular a few years ago when I was more into flightsims. I bought a ton of momitary switches. Im not sure if all the layouts on all keyboards are the same but I will see if I can find the paper I made of the keyboard layout.
    Robbie
    ive got it all figured out now , in the link i posted earlier there is a free software that shows which key has been pressed ,
    i ve had some trouble with limit switches on my router ,so that was the first thing i did , i connected the switches so they trip the reset in mach , with an extra push button switch to trip the reset back again ,all three switches work thru the extra one ,
    unconventional but it works perfect , the table stops pretty much dead nuts in the same spot each time for homing purposes , beats the heck out of eye balling the cutter to the part if or when i loose steps , i work on fast machines at work so i'm not a patient man when running cnc at home so i tend to push the system beyond the limits and loose steps at times
    now i'm hacking another keyboard to make the full controller , ive come to realize i need some serious amount of switches to do what i want to do
    so here is the hack job and some swithes that i have collected , it was simple to find the key combinations , i need to decide what what size of control panel to build and what i will build it out of , the mdf board to mount the electrical on is temporary ,ive added terminals for all the connections
    Jul 2006
    1062
    I see some real potential in what you're doing dertsap :cheers: one thing I may have missed is does WinXP allow you to use 2 keyboards?
    Keith
    i know that two will work if one is thru the usb port ,i will be splicing two together to see if it will work ,so i will keep you posted
    Jul 2006
    1062
    Quote Originally Posted by dertsap View Post
    Thanks for that ....Is it done yet :rainfro:
    Keith
    appreciate the enthusiasm ,
    but no
    i'm currently designing the control board panel on cad ,this will be a bit of a process and time is limited somewhat plus i'm jumping all over getting the first table's few bugs out ,the second has been leaning against the wall on the back burner
    Quote Originally Posted by Kipper View Post
    i didnt hack two together , bought a usb keyboard yesterday ,the two will work fine together ,theres too much keeping up with everthing i have on the go to experiment with it
    Aug 2006
    102
    I have hacked keyboards while building arcades and Jukeboxes. It was "fun" the fist time, but then I invsted the $$ and bought one of these. For as low as $35 there is no guessing or sodering, and its removable ect.. for use on a new project
    http://www.ultimarc.com/ipac1.html
    It allows 2 keyboards and trust me, very easy. You get software to design your layout and program each switch to whatever you want.. no fantom keys. I sound like a sales person but it saved me a buch of time on my second arcade.
    Jul 2006
    1062
    Nice one jdell42 :beer: "bookmarked"
    Keith
    ive seen those units , they are a nice setup , my thing is i have an thing about ripping things apart to see what makes them tick , i didn t find the soldering took too long ,so this was an easy project . if or when i do this again i will probably buy something like that ,
    May 2006
    2420
    Quote Originally Posted by jdell42 View Post
    It is funny when I think of how much money I spent on arcades as a kid, and these days you can put together an old PC running emulator software and run the same games for next to nothing in cost...(chair)
    Russell.
    Aug 2009
    A-D-Controller BU0836
    Google this for cheep usb interface and info.
    i used two and they work well
Page 1 of 2 12
