Is there a way to get the complete stator out of the housing? (1.5kw aircooled chinese spindelmotor)
So now and then i got a "dl"-error ( shortcircuit output). i found that one of the wires touched the rotor and also that the insulation of the wires is cracked on several places. I want to redo the wiring, therefor: removing the coils from the tube would be handy.
It looks like it's glued in there.. I removed the little black screw from the side.
I don't think i have to hammer it out... i tried heating up the outside to 80 degrees Celsius and cooling the coils but no result..
Is there a solution for this???
Kees
