586,103 active members*
3,794 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Slightly wrong size end result
Page 1 of 2 12
Results 1 to 20 of 37
    Aug 2014
    19
    I'm sure I'm doing something incredibly stupid, I'm new to this world, I recently got my first hobbyist-CNC (I'm doing small commission works for modelers mainly) and I'm evaluating madcam and meshcam.
    I made a small model of about 20x20x10mm with small details of up to 0.5mm. The same model, with the same end-mill sizes and same toolpaths config (roughing + waterling + finishing + outline) comes out very close to the 3D model with meshcam (with a 0.05mm resolution) but pretty bad with madcam (with a 0.3mm resolution). I mean the definition of the model is great with both software, simply madcam is always approx 0.3mm off.
    I set the mesh config as suggested in the manual and the tolerance for all tools to 0.01 (I'm working in mm). I also tried other models more or less with the same issue. Oddly enough it seems to always lose approx 0.3mm.
    Post processor Mach3.
    I searched and I haven't seen this issue on the forum so I'm sure I'm doing something terribly wrong, any guidance would be greatly appreciated. Thanks!
    Apr 2003
    1357
    Re: Slightly wrong size end result
    It has to be something wrong in your process. We use madCAM everyday and have for years, and we don't have this issue. Can you post the model, and a description of the tooling you are using? I wouldn't mind reproducing your project to see how it works out for me.
    Dan
    Aug 2014
    19
    Thanks for your reply Dan. I'm sure I'm doing something wrong. I can't publicly publish the model, but it's easily replicable with any relatively small model.
    - A simple 20x20x10mm section of pyramid, hollowed with 1.6mm sides thickness and 1mm-radius rounded corners
    - 3.175mm end mill roughing
    - 2mm ball mill waterlining
    - end mill planar finishing
    I use a rather soft material for prototyping (a heat resistant resin).
    I started over and I'm about to make another test today. Maybe I just made some silly mistake but this problem I'm having is pretty consistent with all the models I bulid. For example I often make a pocket for the stock before milling, and it always ends up ~0.3mm smaller than it should. This doesn't happen with other CAM software I tried (meshcam and also aspire), so it shouldn't be an issue with my router.
    Any idea of what I could be doing wrong?
    Apr 2003
    1357
    Can you go to the page where you select your tool, and post a screen shot of that? I'm interested in seeing the "Speed/Settings" page, and the "Other" page. Can you do this for each of your tools? If you want to go private with this, you can send them to [email protected].
    Dan
    Aug 2014
    19
    I tried again with lower definition and tolerance, unfortunately I got the same result.
    Flat 3
    Ball 2
    Here I tried to set the tolerance to 0.05 but it was 0.01 in the first experiments.
    Apr 2003
    1357
    Hmmm... looks okay.
    You mentioned that you set your mesh tolerances according to the values in the help file, correct? Can you verify that that is correct (and that you are set up with metric values)?
    How are you measuring your finished part?
    Aug 2014
    19
    Quote Originally Posted by Dan B View Post
    Hmmm... looks okay.
    thank you for helping me on this.
    yes, the values are as suggested in the help file. everything's set in mm.
    I use a digital caliper to measure the finished part.
    This is driving me crazy, I love madcam, it's definitely the best of the CAM I can afford (3-axis version) but I don't understand what is going on. Tomorrow I'll try to compare the g-code of a very simple model generated by madcam and other cams.
    Aug 2014
    19
    I did a quick test with a 20x20x20mm cube, roughing with stock to leave = 0 and same tolerance. Same end mill configuration on madcam and another CAM.
    Can it be a problem with the header? Madcam adds
    G00 G49 G40.1 G17 G80 G50 G90 G64
    G21
    the other just
    G21 G64 G17
    G90
    Apr 2003
    1357
    I'm starting to think it's a post issue too. Are you using the default post?
    I'm not familiar with Mach3, but let's analyze this line. Here is what I believe the G-code does:
    G00 -rapid
    G49 -cutter length offset cancel
    G40.1 -possibly cutter compensation cancel, but not sure why it's G40.1 and not just G40
    G17 - XY plane
    G80 -fixed cycle cancel
    G50 -ramp slope control cancel
    G90 -absolute positioning
    G64 - don't know what this does, but a google search leads me to believe it might be for constant velocity mode.
    For a simple experiment, have you tried emulating the other safety line in your mach3 post to see what happens?
    Can you attach your post? I don't keep the old posts I know I'll never use, so I don't have the mach3 post easily available to look at.
    Dan
    Aug 2014
    19
    I attached the two post processings. cube-mesh is from meshcam. cube.txt is from madcam with mach3 post-processor.
    Meshcam creates a lot of "noise", but if you look at the end of the file you can see that both softwares seem to get the geometry right (actually madcam is more accurate). So I'm really out of ideas here.
    I'll try to put the meshcam header into the madcam file and see what happens.
    Apr 2003
    1357
    Can you attach madCAM's mach3 post processor? I want to replicate your experiment here, but I don't have that post.
    Aug 2014
    19
    I probably did something wrong... but isn't it attached to the previous post?
    Apr 2003
    1357
    You posted the code. I want to see the post-processor file that creates the code. Look in your C:\ProgramData\5XCNC\madCAM\5.0\Post Processors. I think that's where they are stored. I keep mine elsewhere, but I only have posts applicable to my situation. The reason I'm not 100% sure that that is the location is because I've had madCAM 5 installed from the earliest beta days, and I seem to recall some shifting around of where files were stored.
    I want to see it to make sure something hasn't changed there that's causing this issue.
    Dan
    Aug 2014
    19
    oh okay, sorry.
    It's a very small file, I'm pasting it here
    Code:
    //MadCAM_POST_2003-12-10
    *VERSION*
    1.0_031210
    *FILE_NAME*
    Mach3_Gcode
    *FILE_EXTENSION*
    txt
    *FILE_DEST*
    c:\postfiles\
    *FILTER*
    0.01
    *OUTPUT_WIDTH*
    4
    *OUTPUT_DECIMALS*
    *SCALE_X*
    *SCALE_Y*
    *SCALE_Z*
    *AXIS_1_CHAR*
    X
    *AXIS_2_CHAR*
    Y
    *AXIS_3_CHAR*
    Z
    *CUTTER_REFERENCE*
    TIP
    *RAPID*
    G00"x""y""z"
    *END_SECTION*
    *RAPID_APPROACH*
    "x""y""z"
    *END_SECTION*
    *RAPID_RETRACT*
    G00"x""y""z"
    *END_SECTION*
    *APPROACH*
    G01"x""y""z" F"feedz"
    *END_SECTION*
    *FIRST_CUT*
    "x""y""z" F"feed"
    *END_SECTION*
    *CUT*
    "x""y""z"
    *END_SECTION*
    *TOOL_CHANGE*
    ("toolname")
    M6 T"toolnr"
    M03 S"speed"
    G01"zhome"
    *END_SECTION*
    *TOOL_STOP*
    M5 M9
    *END_SECTION*
    *PROGRAM_START*
    G21
    *END_SECTION*
    *PROGRAM_END*
    M30
    *END_SECTION*
    *LINE_START_NUMBER*
    Aug 2014
    19
    I did one last test. I reset my whole Mach3 config and started over from scratch (just to be sure it's not a configuration error). I manually edited some gcode and cut a small box out of wood. (X80... Y35... X0... etc...). The end result is just perfect. I can fortunately rule out a problem on the hardware+control software side. I'm out of ideas at this point.
    would a different post-processor work? (eg: standard iso gcode?)
    Oct 2009
    96
    The two files have different size cutters 3.175 on the Mesh and 3.000 and on madCAM?
    Regards,
    Mauri.
    Oct 2009
    96
    I ran both files though a Predator Simulator.
    This simulator provide very accurate simulation.
    First Tests 20.06mm Square
    Second Tests 20.05mm Square
    MadCAM
    G00 G49 G40 G17 G80 G50 G90 G64 G21
    (FLAT_END_3)
    M06 T30
    M03 S16000
    MeshCAM
    G21G64G17
    G90
    (TOOL/MILL,3.1750,0,17.0000,0.0)
    T30 M06
    M3 S16000
    As I do not know the tolerances in both example codes I cannot assume they are the same hence the possible small difference.
    From the simulations I have found that the difference between the two profiles is about .01mm.
    As you can see by the pictures they are very close.
    If you did the tests on your CNC machine and did not change the cutters because on the madCAM you used 3.00mm and on mechCAM you used 3.175mm then this would explain the Error you are experiencing.
    Regards,
    Mauri.
    Aug 2014
    19
    thanks for taking the time to check this.
    I only have 3.175 end mills, "FLAT_END_3" is just a label I use for brevity. I have absolutely no idea why madcam code ends up with a -0.3mm product.
    I have a hobby CNC, but still I managed to get a definition in the 0.01-0.05 range. I have a model with a 5.4mm radius cylinder. On madcam it ends up 5.10, meshcam 5.35. Same cutters. Same config.
    My very inexperienced idea is that madcam resolution --being integrate into rhino- is actually too high for my machine. At this point my options are: make the model slightly bigger or change CAM. It's a shame because madcam is absolutely the best cam I tried so far, especially I need pencil tracing and most of the "entry-level" cam requires a 2D line to do that, while madcam works directly from the 3d model.
    Apr 2003
    1357
    Can you post a picture of your mesh settings? I'd like to compare to mine.
    As for the post, nothing is jumping out at me as a possible problem.
    Don't give up on madCAM yet. It's not the program. We are running 17 seats of it here, and producing a lot of high tolerance parts. We just need to figure out which part of your process isn't correct.
    Dan
    Aug 2014
    19
    This is my config
Page 1 of 2 12
  1. cutting wrong size hole
    By macplus in forum Uncategorised CAM Discussion
    Last Post: 11-30-2014, 11:23 PM
  2. G540 cutting size wrong
    By Ed Williams in forum Gecko Drives
    Last Post: 10-30-2011, 01:53 AM
  3. Wrong Ballscrew Size?
    By ozzie34231 in forum Linear and Rotary Motion
    Last Post: 01-04-2008, 06:23 PM
  4. Purchased aluminum, sent wrong size, too big, now what?
    By pzzamakr1980 in forum MetalWork Discussion
    Last Post: 09-20-2007, 03:54 PM
