I finally finished my CRP 4848 4'x4' nema 34 machine from cncrouterparts. However I am having issues and I believe I have tracked it down to one of the G201x drives. I had issues with the z axis not responding, however the motor did have holding torque. I tried different motors, on the z axis and had the same issue. I then moved the suspect G201x to a different axis, and position, on the PDMX-134 and the same problem occurred on the new axis and disappeared from the previous one.
When the suspect G201x is not responding, I can see that the PDMX-126 is sending signals to it (LEDs on board) but the led on the 201x does not glow brighter, when receiving a signal, or flicker at the end of the movement like is typical.
Does this look like a faulty g201x or am I missing something?
