586,103 active members*
3,446 visitors online*
    Aug 2008
    6
    Heidenhain DPRNT equivalent
    I've a 5 axis mill with iTNC530 and want to be able to view from status monitoring software the value of a variable set in Q99.
    In Fanuc I could DPRNT this out via RS232.
    Is there an equivalent in Heidenhain world please?
    Or. via tcnrmo/tnccmd on a local PC it is possible to view Machine Parameters and other bits of data in the control over Ethernet but I cannot find out if its possible to view a QXX variable.
    does anyone know the syntax to do that?
    Or can I create a Machine Parameter and use it as a variable that tnccmd will view, something like MP99 = Q99 and the MPGET 99 (assuming for the moment that there isn't a machine parameter 99 already existing)
    Hopefully.
    May 2004
    97
    Re: Heidenhain DPRNT equivalent
    FN16 FPRINT is what you need. You can then set up a TNCCMD script to automatically obtain the value. PM me if you want more details.
    Aug 2008
    6
    Sorry, a bit late to reply I know. Yep I found that shortly after I posted but forgot I had. But thanks for the response.
    Aug 2021
    7
    Quote Originally Posted by guypb View Post
    Hi guypb, I am looking for manual/example of using tnccmd to extract cutting time from Heidenhain controller, can you please share me the information if you have?
    Thank you.
    Apr 2019
    6
    Cutting time and anything else is possible:
    https://www.heidenhain.com/products/...cted-machining
    With HEIDENHAIN DNC (RemoTools SDK software development package) you can solve anything...
    In the end, of course, you will realize that you need the StateMonitor application.
  1. Pulse equivalent
    By Sean42 in forum Chinese Machines
    Last Post: 04-05-2020, 05:06 AM
  2. Need Help With DPRNT to usb
    By Gunner52 in forum Haas Mills
    Last Post: 06-13-2014, 02:38 AM
  3. DPRNT
    By TiagoISICOM in forum Fanuc
    Last Post: 04-05-2013, 12:32 PM
  4. DPRNT help
    By DerbyCountyFan in forum Haas Mills
    Last Post: 02-11-2011, 01:56 AM
  5. Do you use DPRNT?
    By gar in forum Haas Mills
    Last Post: 10-23-2007, 04:02 PM
