586,501 active members*
3,263 visitors online*
IndustryArena Forum > CAD Software > Solidworks > How To Fix Part of Assembly ?
Results 1 to 3 of 3
Threaded View
    Jun 2008
    475
    I need some help on this please...
    In the assembly below, I have the square tubes mated to the C channels. When the assembly is moved the center square tube does note move properly with it b/c there is only the mates between the top of the square tube and the bottom of the channels. I thought about making very small diameter holes through the tube and channels and mating the holes to lock them together but that doesn't seem right and will clutter up drawings made from the assembly.
    What is the best way to lock these parts together ?
    Thanks !
  1. Part mode to assembly mode
    By Joesph Jackman in forum CamWorks
    Last Post: 12-21-2011, 07:41 AM
  2. Body into new part within assembly
    By oakleigh in forum Solidworks
    Last Post: 03-09-2009, 10:00 AM
  3. Convert part w/ bodies to assembly?
    By Rich05 in forum Solidworks
    Last Post: 02-03-2009, 05:35 PM
  4. A light-weight table/bearing assembly with a low part count.
    By greybeard in forum Linear and Rotary Motion
    Last Post: 11-10-2005, 12:16 AM
