586,065 active members*
4,627 visitors online*
    5
    VNC 510C Chip Conveyor
    We have 2 Mazak VNC510C's & due to the type of parts that we manufacture we only need to run our chip conveyors a couple of times per day to avoid coolant loss. Does anyone know what parameters to change in the Fusion control to disable the conveyors running except when the operator manually presses the button to turn the augers & conveyor on? I found the attached pdf file on another thread, but am unsure if it applies to my control.Thanks for any help you could provide!
    5
    Re: VNC 510C Chip Conveyor
    I actually found my own answer in the paperwork in the electrical cabinet of our machines. The parameter for our machines was RB18 bit 7, however it looks like different conveyors may use different parameters. I can in no way recommend that you try using this info. Check the back of your machines for the paperwork on the conveyor & the BOM where I found ours, or contact Mazak service before making ANY parameter changes.
  1. MCD-500 Chip conveyor won’t turn on
    By M_D in forum Haas Mills
    Last Post: 08-06-2014, 09:11 PM
  2. Hennig Chip conveyor
    By brandonzp in forum Okuma
    Last Post: 09-01-2012, 10:42 PM
  3. Chip conveyor for LB15
    By cad01 in forum Okuma
    Last Post: 12-10-2011, 05:11 AM
  4. puma 160 chip conveyor
    By driftbuster50 in forum Daewoo/Doosan
    Last Post: 04-20-2011, 02:03 PM
  5. 4020 chip conveyor?
    By MBX5 in forum Fadal
    Last Post: 08-26-2010, 04:09 PM
