586,051 active members*
3,776 visitors online*
    Feb 2010
    17
    Sodick A280 Wire Edm
    This machine has been running fine. I needed to move the table in MDI mode so I pressed the X- button and the machine gave a "Heat Stop by Overload" error. I have seen that error before so I rebooted the computer. Usually that error goes away. I checked the two Servopacks and the lights appeared to be OK. I rebooted the computer and pushed the X- button but now the machine moved in the X+ direction until it hit the X+ limit switch. I rebooted the machine again and tried a move. No matter which button I pushed (X+, X-, Y+ or Y-) the machine moved in the X+ direction until it hit the limit switch. I changed both servopacks and I still have that problem.
    I can program moves in MDI mode and both axes move correctly except that now it moves approximately twice as far as programed. I can go into "Cutting" mode, program a distance and it will cut a part just fine.
    Jul 2004
    235
    Re: Sodick A280 Wire Edm
    I don't know this machine, but is it possible you were not in MDI and in Setup, accidently, and the x- changed some setting therein. If you hit the key, thinking you were in MDI and really you were accidently in the setup screen... then you could have accidently changed a setting, and some setting don't like minus...
    I would look at, when you accidently hit the setup screen button instead, what window pop's up, and did somthing happen therein?
    Only a thought...
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
  1. Sodick A280 radius programing
    By rfarleman in forum EDM Discussion General Topics
    Last Post: 03-12-2020, 02:12 PM
  2. Sodick A280 - Floppy won't initialize
    Last Post: 05-21-2018, 06:09 AM
  3. Sodick A280 boot issue
    By morehelium in forum EDM Discussion General Topics
    Last Post: 04-23-2013, 08:36 AM
  4. sodick a280
    By jeromep in forum EDM Discussion General Topics
    Last Post: 03-22-2013, 02:39 PM
  5. sodick a280
    Last Post: 02-18-2009, 10:40 PM
