586,553 active members*
3,385 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Trying to create a mold with an STL file
Results 1 to 6 of 6
    Sep 2014
    a friend of mine is an ice sculpture, and we are trying to do some awesome stuff on his CNC in ice.
    We want to take an ice block, cut it in half, and engrave a left and right side of a battleship, fill it with snow, and melt the two blocks back together.
    I have an awesome model i found on the internet and have been able to import it into bobcadcam, but only as a stl. well actually as an obj, but i could import it into rhino and export an stl and it came out.
    I used to use CamBam, and it had a mold setting i could use to change the model to a mold. I have not found a comparable function in BobCadCam, and the torchmate router my friend has doesn't play nice with CamBam when we try to create waterline toolpaths. we got BobCadCam to solve that problem, we have V25 btw.
    So i found out that stl's don't like boolean functions, so i can't just subtract a mold, what are my other options? i thought a mold function would be in BobCad, but i guess not. Thanks in advance.
    Regards,
    Scire
    Dec 2008
    4548
    Re: Trying to create a mold with an STL file
    You could use BobArt and emboss from component (choose the stl) and use a subtract option....
    The other thing you could do is part the model in Rhino into 2 halves then export those (if it's symmetrical, then you only need one half)
    Oct 2010
    1189
    Openscad worked for me ,..
    Sep 2014
    Thanks for the suggestion, i was hoping to not learn a third program to do this. I was under the impression that Bobcad CAM was supposed to be able to do this. Looks like i'm SOL and will have to figure out why cambam isn't playing well with the Routermate my friend has. I will try bobArt, i haven't messed with that at all.
    Regards,
    Scire
    Oct 2010
    1189
    I also have bobcad but i only use the Cam ,..
    Dec 2008
    4548
    Quote Originally Posted by Scire View Post
    Regards,
    Scire
    Here is BobArt doing a battleship STL split. The STL is a solid and I did an emboss subtract from the centerline.
Name:	battleship emboss.jpg
    The underside of the surface:
Name:	battleship underside.jpg
  1. LOOKING FOR CAD OR SIMILAR FILE TO CREATE CNC MOLD FOR SKATEBOARDS
    By FINNIFSKATETEAM in forum RFQ (Request for Quote)
    Last Post: 08-13-2014, 07:29 PM
  2. Replies: 8
    Last Post: 06-29-2013, 05:10 AM
  3. RFQ: Create STL file from 2D JPG
    By magda in forum RFQ (Request for Quote)
    Last Post: 01-14-2013, 07:55 PM
  4. How to create mold to copy existing items?
    By Jakobud in forum Moldmaking
    Last Post: 12-04-2010, 02:54 PM
  5. create mold cavity
    By Rob 1264 in forum Uncategorised CAD Discussion
    Last Post: 05-09-2008, 05:04 PM
