586,112 active members*
3,045 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > OK to use the 5V and 24V outputs from my spindle VFD to feed the KFlop?
    Mar 2007
    156
    I am putting together a 3 axis CNC mill system using the KFlop and KStep. There is a VFD which is used to power the spindle.
    The VFD has 5VDC and 24VDC auxiliary outputs in addition to its normal VFD motor output. It would be convenient to use this 5VDC supply to power the KFlop and the 24VDC for the limit switch and input circuits. This way, I would not need to install dedicated 5VDC and 24VDC power supplies.
    My question is - will this work acceptably, or do you expect excessive noise on the 5V supply from the VFD such that it might cause problems?
    Jul 2013
    24
    Re: OK to use the 5V and 24V outputs from my spindle VFD to feed the KFlop?
    As long as you are not exceeding the current you shouldn't have any issues, it should work fine.
    Jade York | (888) 939-7250 | www.repairzone.com
    "Your Servo Motor and Industrial Electronics Specialists"
    May 2006
    4045
    Hi PhoenixMetal,
    If the current is sufficient it should work. But are the 5V and 24V GNDs common? If they are common then you will defeat the opto isolation of the KSTEP inputs. That would couple any noise picked up by the limit switch wiring into KFLOP GND that would not be coupled if an isolated 24V supply was used.
    HTH
    Regards
    TK
    http://dynomotion.com
    Mar 2007
    156
    Ah yes - the 5V and 24V grounds are common. I will get a separate dedicated 5VDC power supply to maintain the isolation. Thanks for the input!
  1. Mach3 + Kflop + VFD = Spindle Speed control?
    By slimneill in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-07-2015, 06:22 PM
  2. KFLOP to Spindle VFD Controller (cnc4pc C6 board) struggles
    By mckoz in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-18-2014, 10:38 PM
  3. Kflop spindle PWM control -10 + 10v
    By markder13 in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-02-2014, 06:27 PM
  4. KFLOP: How to modify spindle speed PWM from SpindleMach3PWM.c
    By PapstDFrisco in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-04-2013, 08:29 PM
  5. M2 External Outputs - Feed Hold, Emergency Stop
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 02:49 PM
