586,060 active members*
3,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Help! Bridgeport Interact Series 1 MK 2 with Contraves spindle drive.
    Dec 2013
    4
    I have a Bridgeport series one mark 2 Interact with TNC151 and a Contraves spindle drive. I have no circuit for the contraves bridgeport installation, as my manual only has the KTK drive set up. I did manage to get the service manual PDF for the Contraves off the Contraves website, which includes a full schematic of the CRU and main PCBs, however my BP's Contraves spindle box has an optional card installed labeled "FRU", this is where the S Analogue voltage is delivered. I would like to know what this board does, and how to adjust it. My guess is it does some kind of signal shaping that the TNC151 can't manage?
    I have a 4kW RPC, and it is quite okay to run the spindle up to 3750 rpm with this, but you have to set the Analogue Spindle Slope (MP168) to a very low value so the spindle spins up over a couple of seconds, I am fine with this for what I do. The issue I have is that the Contraves card can lock up if I set it's internal slope Lin pot too high and the TNC151 does not know the card has tripped, the asterix keeps flashing. I am convinced there is a wiring problem and this should cause a spindle fault. A second problem is that an M05 command over 1000 rpm appears to slam the spindle brake, sounds like a mallet is hitting the machine. However, the machine does not reset and seems quite happy mechanically.
    -Hazel
    Jan 2012
    8
    Re: Help! Bridgeport Interact Series 1 MK 2 with Contraves spindle drive.
    Hi hazelchase
    can u share the contraves manuals and schematics for the interact i mk2 cnc machine?
    We have 3 weeks with our machine down:
    need to service the spindle motor with the KTK drive unit looking for the following items:
    • P/N for air blower, this is burned
    • P/N for new bearings
    • P/N for armature brushes
    • P/N for tacho brushes
    Thanks in advance for the information
    Regards
  1. bridgeport interact 4 spindle drive
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 09-17-2023, 11:32 AM
  2. Bridgeport Series II Interact 2 -- how to remove top plate above spindle
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2010, 10:55 PM
  3. Top spindle I.D. on a Bridgeport Series II Interact 2
    Last Post: 08-11-2010, 01:49 PM
  4. Bridgeport Series II Interact 4 Spindle Brake
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2009, 06:22 PM
  5. BP series II Interact 4 to Contraves Contl?
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 08-16-2007, 09:46 PM
