586,103 active members*
3,314 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Milling an 1/8" slot in 304 stainless with my G0704
Page 1 of 2 12
Results 1 to 20 of 23
    Feb 2014
    197
    Can anyone please give me some input on this. Maybe speeds and feeds as well as setup. I haven't bought the end mill yet so tips on that would be good to. I mainly plan on doing aluminum but a friend asked if I can make this slot for him. It's less than 1in. in length and it will be all the way through a 1" disk of 304 stainless.
    TIA
    Jan 2008
    1529
    Re: Milling an 1/8" slot in 304 stainless with my G0704
    Could be fun...
    Consider drilling the majority of the material out then milling to shape.
    Nov 2009
    4415
    Patience? I hate 1/8" tools
    A lazy man does it twice.
    Aug 2008
    962
    +1 on pre-drilling most of the material out first ..
    Just broke a 1/8" end mill yesterday trying to cut a 3/4" deep slot in aluminum. It was a 4 flute end mill (cause that's all I had on hand)
    I did have both ends of the slot pre-drilled to depth .. taking .05 doc @ 7200 rpm & 13.8 fr - which is the recommended speed & feed in G-Wizard on conservative setting.
    To get to that depth takes an 'extra long' end mill in 1/8" diameter .. which translates to 'extra tool flex' as well.
    Be sure to buy more than 1 tool for the 304 job!
    May 2005
    3920
    Quote Originally Posted by Potatohead908 View Post
    TIA
    Fair warning this could be frustrating to the point of you throwing your mill out the window. If by the description you have above you mean a 1" thick piece of stainless it could get ugly and expensive. There are two distinct problems one being that Stainless work hardens real fast. The other related problem is that the chips are damn hard and will chip or break end mills real fast.
    The recommendation to drill out the slot first might not be a bad one, but even with drilling you have to take special care and use good tools suitable for stainless. When drilling you will want to select a spindle speed well below what you would use for mild steel and feed the drill without stopping or hesitating. You stop or hesitate and you run a good chance of work hardening the surface you are trying to drill through. However it is very difficult to drill an 1/8" hole in just about anything with out clearing chips and the flutes. So you need a withdrawal technique that doesn't allow the drill to rub. As you can see just drill holes can get ugly.
    You could mill the slot all the way through and you might have to if wall surfaces are important. The problem here being drill bit wander and deflection of the end mill as it tries to clear metal between the drilled holes. You might take the advice already suggested above of drilling two holes at either extremes of the slot and mill out the solid in between. The thing here is that the drilled holes will allow you to dwell a bit and adjust the depth of cut before actually cutting anything. More importantly it should allow you to completely clean the slot before each pass, as noted recutting chips is hell upon your end mills. When doing this do not use an excessive depth of cut as you want to be able to maintain a feed rate suitable for the spindle RPM, agan rubbing frm hesitation or dwelling can cause instant work hardening of the stainless.
    In any case order lots of coated end mills suitable for stainless. If this is your first attempt at machining stainless it could get very ugly, epsecially when this is at best a bad operation to cut your stainless machining experience on. Oh before you even start find out how valuable this stainless piece is because honestly you may want to decline the opportunity to do this job for your friend. Everything considered it would be far better to learn machining of stainless on simpler tasks.
    Aug 2008
    187
    save yourself the headache, have your buddy send the part to a shop with EDM.
    May 2005
    3920
    Quote Originally Posted by bjones View Post
    This makes a lot of sense and it is one simple sentence.
    Jun 2009
    195
    ya what he said ------^ you will thank us later !!!!
    Nov 2009
    4415
    So will your friend!
    Feb 2014
    197
    Thank you to all that replied. So for clarity it is only 1/8th inch thick 304 (or so he thinks), 1/8" slot less than an inch thick. It's for a finger/hand guard for a knife he is making. To make things worse I just converted my G0704 to CNC and am a total greenhorn to machining!! It's a small piece so not a big loss if I total it. The bit he has bought but we only have one. It is a 90 degree carbide bit made by Melin that has an AlTIN (Aluminum Titanium Nitride) coating. I told him to just make it thicker and out of aluminum but he is set on stainless. I just did a big order from Enco and added his mill bit to get the free shipping. If need be I can pass on the favor and just keep the end mill for something else. Or I can just try and if the bit breaks then....we tried!
    Jan 2008
    1529
    So the requested slot in 1/8" wide, 1 inch long, through 1/8" thick material?
    Feb 2014
    197
    Yes. Sorry if I haven't made that clear.
    Aug 2008
    187
    that makes one heck of a difference in what we thought you were attempting, 1/8 thick stock should be easy enough but you need to be clearer in what you are saying. "1/8th slot less than an inch thick" still sounds like you want to go nearly an inch deep. do you mean nearly an inch long?
    Feb 2014
    197
    Ok sorry I wasn't clearer. This is for a finger guard on a knife my friend is making. It's a piece that is sandwiched between the blade and the handle. The material is less than 1/4" thick and I hope closer to 1/8th". The slot needs to be close to 1/8" wide. I don't know the length yet but it has to be under an inch.
    I changed my previous post. Totally screwed up what I was trying to say.
    Nov 2009
    4415
    That should be much easier.
    Since you are green, try using the wizards. They are built in to Mach if you are not familiar with them. The wizards are designed for simple tasks. Multiple operations can be linked together if so desired. Those gcodes can also be saved if you were doing a process repeatedly.
    Jun 2010
    4256
    1/8" slot in SS? I would be tempted to buy a 3/16" 3/32"carbide drill and drill most of the slot out first. Slow revs and aggressive feed and air blast to clear the chips out fast. Then mill the slot to size with medium revs, medium feed (ie avoid work-hardening!) and lots of shallow cuts. Put some oil in the air blast to keep the cutter wet and avoid metal sticking to the cutter.
    Cheers
    Apr 2006
    3206
    Use a 3/32" endmill. Run it down the middle, then climb cut up one side, then move over and climb cut down the other side...... .125 - .094 = .031
    .031 / 2 = .0155/side stepover. I'd do a rough pass and a .003" finish pass on each side.
    You can use a good quality 3fl solid carbide endmill at around 350SFM, dry w/air blast, around .0018"/rev feed rate. DOC no more than 1/2 Dia of cutter.
    I use this approach all the time for O-ring grooves in 304. Like RCaffin says, don't baby it, it will work harden, but it's not all that bad. 304 has a reputation far worse than it deserves.
    Aug 2008
    187
    Quote Originally Posted by RCaffin View Post
    1/8" slot in SS? I would be tempted to buy a 3/16" carbide drill and drill most of the slot out first. Slow revs and aggressive feed and air blast to clear the chips out fast. Then mill the slot to size with medium revs, medium feed (ie avoid work-hardening!) and lots of shallow cuts. Put some oil in the air blast to keep the cutter wet and avoid metal sticking to the cutter.
    Cheers
    uh, 3/16" is bigger than 1/8" mate.
    Jun 2010
    4256
    Errr ... yeah ... oops!
    Corrected.
    Damn imperial measurements - give me metric any day.
    Cheers
    Feb 2014
    197
    So I pretty much hosed the first part of this thread up.....BUT that doesn't matter so much. I talked to my friend and he found the receipt that says it's 303 Stainless. I asked him what the height of the material was that I need to slot all the way through. He said 1/2". So to recap....1/8" wide slot (doesn't need to be right on the gnat's ass), less than 1" in length all the way through a 1/2" tall piece of 303 stainless. I think I read that 303 is not as hard to machine as 304. Is this correct or am I still pretty much going to break some end mills? I have a 60 gallon air compressor to keep the chips at bay. I understand some of the wizards in Mach3 and I can practice on some softer material before I make the cut....ie wood or plastic or aluminum.
Page 1 of 2 12
  1. Cutting 0.5mm wide slot in stainless bolt head
    By greybeard in forum Material Machining Solutions
    Last Post: 06-18-2012, 05:28 PM
  2. slot cutting in stainless steel tube
    By brbeardm in forum MetalWork Discussion
    Last Post: 07-20-2011, 03:22 AM
  3. BF20's, G0704's, etc. and Y loss with 4" milling vise
    By photomankc in forum Benchtop Machines
    Last Post: 12-28-2010, 03:54 AM
  4. Replies: 6
    Last Post: 06-24-2008, 01:14 AM
  5. Machining a Slot in Stainless Steel
    By ngr1 in forum MetalWork Discussion
    Last Post: 10-04-2005, 02:20 PM
