586,051 active members*
3,695 visitors online*
    Nov 2012
    6
    colchester combi 4000
    I purchased a used Colchester CNC Combi Flatbed lathe a few weeks ago. After getting it started up and running I am having a few small problems that I could use some assistance with.
    Make : Colchester
    Model : Combi 4000
    Serial : E50017
    YOM: 1998
    Control : GE Fanuc 210i - T
    The Rapid Traverse Parameter at 1420 and 1424 are default set to 1000mm/min. I am able to change these values to 8000 and 12000, however when I cycle start the control automatically reverts to 1000mm/min.
    I fear that one of the lubrication lines is broken, I will have time to fix in the coming weeks, but for now I need to run machine. Problem is the lube pump is set on a timer and is going through approx. 3L of way lube in 8 hours. I would like to know the location of the timer in the control so that I may set it to larger intervals for the time being.
    Finally I had to service the gibs on the saddle, and when we did this we removed the wipers from the saddle. They crumbled due to age and I was wondering if there was a replacement part in stock for these.
    Thanks for your time.
    Brandon Goodwin
    Apr 2010
    45
    Re: colchester combi 4000
    Hi I can help you with those problems I also located in Toronto Ontario sent me an email at [email protected]
  1. colchester combi 2000 diplomatic turret.
    By Toolmaker666 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2009, 03:43 PM
  2. Combi or sepreate???
    By Mark Sted in forum Benchtop Machines
    Last Post: 01-30-2009, 02:49 PM
  3. Combi or seperate machines
    By Mark Sted in forum Uncategorised MetalWorking Machines
    Last Post: 01-28-2009, 03:35 PM
  4. NH 4000 dataserver
    By smecher in forum Mori Seiki Mills
    Last Post: 10-21-2008, 10:06 PM
  5. Colchester Combi 4000 (1998)
    By gollame in forum DNC Problems and Solutions
    Last Post: 07-31-2007, 05:55 PM
