586,047 active members*
3,787 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Needing advice / help with 3040T D-2 Homing issues and or possible settings issue..
    Sep 2014
    First of all ..Hello! I am new to the CNC process...and this site..WOW, there are some things in here far above my paygrade lol..LOTS of information.
    I ( like seemingly most novices,) just bought a 3040T D-2 ( chinese made version of whatever ) ...my issue is less of a technical problem...and if I'm being honest more of a "operator error" issue I'm sure....
    That said, i have the machine up and running using Mach 3... I have watched the tutorials and read the techs...and I am now ready to admit..I don't have a clue where to go from here....I have set the units to Inches...but all the speccing in the is in MM's ...in working out the conversion ...the math is correct...however when I try to set my homing I'm missing something.
    I parked the motors XYZ in the lower left hand corner of the table... using the soft max as X = 290, Y=390 and Z= 0 and of course the soft min limits as X=0, Y=0 and Z=-56....the only thing checked on the homing setup screen is the "Auto Zero" Column.
    When I click go to home or try to run a gcode... you can tell the motors are trying to go..somewhere...but it's certainly NOT the coordinates listed....
    As I said I am SURE there is something I have NOT done ..correctly...any help would be GREATLY appreciated
    Thanks Guys!
    Re: Needing advice / help with 3040T D-2 Homing issues and or possible settings issue
    Does the machine have home switches?
    Are you clicking the Ref All button to home it?
    There is no Goto Home button, so not sure what you're trying to do there.
  1. Replies: 0
    Last Post: 09-09-2014, 03:05 AM
  2. Homing Issues
    By kmbcnc2012 in forum SmoothStepper Motion Control
    Last Post: 01-13-2013, 10:00 PM
  3. New guy needing advice!
    By ThatguyDave in forum Fadal
    Last Post: 05-22-2009, 02:36 AM
  4. Help please? Homing issues!
    By D.L in forum Mach Mill
    Last Post: 03-02-2009, 05:32 AM
  5. Student needing Advice!!!
    By mtr17 in forum Vacuum forming, Thermoforming etc
    Last Post: 01-29-2007, 10:31 PM
