586,102 active members*
2,606 visitors online*
    Sep 2014
    Jungner 560 Y Axis Ballscrew
    I have been elected to the position of ballscrew expert at work. :drowning:
    We have a Jungner 560 needing a Y axis ballscrew rebuilt/replaced. We have several old ballscrews on hand but none have been tagged as to machine, axis, etc...
    Here is the problem...the boss wants a rebuilt Y axis on hand and ready to pop in the machine. I need to see if we can identify one we have on hand as the correct one.
    Does anyone out there have specs, part #, pictures, any info that may be of help?
    Jun 2004
    511
    Re: Jungner 560 Y Axis Ballscrew
    Jungner is not supported in the US. We have one, and the only info I could find was from an old dealer in the New England area.
    Oct 2005
    859
    Jungner no longer has service dealers in the US. Y axis Ball screw made by IBL part numbers on screw nut include 73-09252-01 and 032-05-03-0437-878 (I can not find a cross reference to it on Thompson site). The screw is 32 mm RH pitch 5mm. It has a 25mm bearing diameter on the end with a smaller 19mm extended from there. The nut has a 48mm diameter (D1) and a flange with a 60mm BHC. These appear to be special made nuts for Jungner as they do not spec to the shelf parts.
    My email is [email protected] and I once serviced Jungner machines in the USA. I do not have numbers on all the other parts but may be able to get them if my contacts can help.
    Yes I can get full dims for the screw currently I have a used one I will be sending out for rebuild for a company now.
  1. Jungner Grinders
    By tjones in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-10-2014, 02:07 PM
  2. Jungner
    By ifixcnc in forum Toolgrinding / Toolgrinding Machines
    Last Post: 07-24-2013, 06:39 PM
  3. in need of a z axis ballscrew
    By williamsmotower in forum Charter Oak Automation Support Forum
    Last Post: 02-08-2012, 05:57 PM
  4. Using a ballscrew on the Z axis
    By uspl in forum Linear and Rotary Motion
    Last Post: 05-16-2011, 09:56 PM
  5. VF0 X axis ballscrew
    By Geof in forum Haas Mills
    Last Post: 09-20-2006, 06:44 AM
