I'm building (what hopefully will be) a pretty solid and rigid gantry-type cnc machine out of 80/20.
The gantry will ride on overkill THK HSR35 rails.
I would like to experiment with mounting a ~35mm diameter ballscrew on one side of the gantry, rather center & under the table.
I can see the possibility of racking with some less stout (v bearings) setups, but don't see it occurring easily with a good quality linear bearing setup.
Any opinions on this?
Eventually going to be moving to a nut driven setup using a 75" long ~1.5" diameter screw mounted on the side as well.
