586,103 active members*
3,219 visitors online*
    Oct 2004
    85
    pierce delay in Mach 2 ?
    How can I change the pierce delay in Mach 2. It seems to be sitting there too long.
    Jul 2005
    2415
    Open MACH2. Go to Ports & Pins/Spindle Output (may be in another spot in MACH2, haven't run it in over a year). Turn off any Spin-up spin down delay.
    Let the Arc Good signal set the pierce delay.
    Nov 2011
    hi redline i had same problem, [was sore on tips], had turned off any spin up/down delays still no good so with some long evenings i found in general configuration look for g04 dwell in ms and click it off or switch it off it worked fine after that..
