Re: Magnetic starter | contactor to start and stop cnc
Originally Posted by
Novett
Hi
I just received my 3 pole 115 volt contactor from Automation Direct. I found some videos online.
I used the videos to create a wiring diagram. I`m hoping someone could check my diagram.
The link I posted had it on p4 among others.
True about the RC snubber across the coil if AC, you can only use a rectifier if the coil is DC.
Al.
Albert E.
