586,105 active members*
3,220 visitors online*
    GILDEMEISTER N.E.F CT40
    Dear All,
    every thing working for CT40 except the spindle does not work in manual or in auto mode, there is no alarms appears
    can any one help to solve that?
    Best regards,
    Sting
    Nov 2013
    32
    Re: GILDEMEISTER N.E.F CT40
    Check chuck... (IN or OUT chucking )
    Check chuck pressure and pressure sensor....
    Check chuck inductive proximity switches (maybe one is not working or both are working or one is defective and always work meassure them with instrument because lamp indication on sensors is not true and real information)
    Check Spindle Drive... (does he have BB signal then does it get RF signal)
    Check Spindle Motor (brushes, tacho brushes)
    Dear Crocole,
    Thanks for your reply, regarding the check of chuck , i think if there is something not ok there will be an alarm but i do not got any alarms
    i will check the spindle drive, the spindle motor is tacho brushes
    Nov 2013
    32
    Are u trying to clamp/unclamp piece in Jog mode or in MDI with M function? Can u do the main spindle transmission change? (there should be spindle movement in that function to get gearing in alignment )
    i can clamp and unclamp the chuck in jog mode and there is 2 proximitys to check the situation of the chuck , when the chuck is not clamped on a work piece an alarm 31 is issued
    i do not know the M codes for chuck clamp/unclamp, i tried M10,M11 but it does not work and alarm 20 appears
    for main spindle transmission change, i do not know the codes, do you mean gear change code such as M41,M42? i tried that and also does not work and alarm 20 appears
    i do not have manuals for that machine
  1. Gildemeister NEF CT 40
    By gugu in forum Mini Lathe
    Last Post: 03-26-2021, 10:06 AM
  2. Gildemeister NEF CT-60
    By ragunath400 in forum Controller & Computer Solutions
    Last Post: 05-11-2014, 08:16 AM
  3. NEF CT40 - EPL2 manual
    By Matyi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-13-2014, 11:20 AM
  4. Gildemeister T-42
    By lonely in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2008, 01:57 AM
  5. CT40 vs. BT40 spindle's and tooling?
    By gunsmither in forum Haas Mills
    Last Post: 01-09-2007, 05:06 AM
