586,119 active members*
3,586 visitors online*
Results 1 to 6 of 6
    4826
    Effect of T0 (tool offset cancel)
    In Camsoft CNCProfessional v14.7, when a lathe tool call is made, the current Horz and Vert offset amounts can be seen to be implemented immediately on the axis displays. This is fine by me.
    Now, to undo that effect, a T0 in the program works perfectly, that is the displays revert back to the axis positions with no offsets applied.
    My question is this: is it possible to mimic the effect of the T0 command within a logical statement of some sort, other than actually keying it in, in mdi?
    In a similar vein, is there a way to force the Axes Displays into absolute display mode via a logical command? I wish to ensure that when using the READOUT command, that the proper axis display mode is in use.
    May 2004
    8
    In the current version the logic commands are:
    ABSCODE =Axes Displays into absolute display mode
    TOOLPARAM OFF logic command equivalent of T0
    4826
    Ah yes, ABSDISP, that sounds familiar Its been a while for me.
    I wasn't sure if TOOLPARAM OFF had deeper tentacles into the logic than what it might seem.
    Thanks.
    Apr 2005
    51
    Mr agentsmith you are wrong. Mr huflungdung is right.
    It is the ABSDISP command to change the readout. The ABSCODE changes the G code like G90.
    I use small case t=0 in code instead of TOOLPARAM OFF
    Carlo
    4826
    Thanks Carlo, I'll try the t=0 since TOOLPARAM OFF does not seem to do quite what I want.
    4826
    Yes, t=0 within the logic works perfectly, and the display readouts respond immediately as well.
