586,389 active members*
3,230 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Troubleshoot spindle start
    Mar 2008
    25
    Spindle won't start with switch in "computer" position? I hear a snap like a relay activates but no joy? Spindle does start with same switch in min-max rpm position?
    Intelitek prolight 3000 lathe, intelitek software program.
    All cnc stops at line with g32 canned threading, like controller doesn't recognize canned cycle.
    Any and all comments would be helpful.
    Thanks in advance
    Mike
    Nov 2008
    43
    Re: Troubleshoot spindle start
    Did you ever figure out your problem? i having the same issue right now with my prolight 3000.
    Nov 2008
    43
    do you still have this issue? i have the opposite problem. everything works on cnc but on manual it doesnt.
  1. Spindle Won't Reach Speed after Brake On while Spindle Start
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2014, 04:59 AM
  2. Replies: 3
    Last Post: 01-22-2014, 01:25 AM
  3. Mikini troubleshoot (spindle suddenly stops)
    By roberto123 in forum Mikinimech
    Last Post: 11-19-2011, 05:00 PM
  4. Help troubleshoot Lincoln SA 200
    By aawelderswife in forum Welding Brazing Soldering Sealing
    Last Post: 07-19-2008, 03:08 AM
  5. Troubleshoot DNC
    By phoodieman in forum Uncategorised MetalWorking Machines
    Last Post: 09-21-2006, 07:44 PM
