Originally Posted by
LZ1TWB
Hello DimiOrla,
I could tell you some tips about this motor.
First of all it is unipolar, which means it has twice as much wire in itself with twice lower cross section. Unipolar motors are easy to control as you need only 4 transistors to turn each of the 4 coils to ground / two by two coils are connected with a centre to + voltage/ Driving a unipolar motor in bipolar mode is not good as only one of the windings is used - you cannot put much current in it and the torque is then less. It is said that a bipolar motor compared with the same size unipolar has more torque because you have only two coils with thicker wire that can conduct more current before getting too hot.
DennisCNC said that it is low resolution motor 7.5 degrees step - try using some like 1.8 as they are more common, which driving it in half step gives a 0.9 step. If you intend to use a gear you have to spin it quite fast in order to have some good speed of travel. 24V is high for a cnc motor and if you drive it with a 24V supply you will certainly get nothing from it as current cannot get high enough to maintain the desired torque /coil induction issues/. It will be limited to certain rpm. Stepper motors are mostly used with a voltage many times bigger than the specified, but of course some sort of current limiter should be placed. Most steppers have a low voltage specified 2-3Volts but are normally used at 24 for example. Higher voltage means more torque at high speeds.
There are so many things that could be said about steppers, just ask if you need something, I see you are going to learn in cnc stuff, keep going, it will become very interesting to you.
I remember my first cut on my mill, I've drawn half a ball and machined it in foam and was pretty happy then.
Greetings,
Todor
P.P. - someone correct me if I've made a mistake somewhere.
