I want to build a 4 axis cnc router to do lateral movements with the spindle (as shown in the figures below, with the cutting tool out of the line of the axis of rotation ). Not yet have a 4 axis. If I insert geometries on g-code generators softwares (Mastercam, Bobcad, etc) with holes like this in the figure below (to 4th axis), the tool need to side movements (like cutting cnc Video below). The G-code generators for 4 axes already consider the machine can move laterally or so I need to modify the machine? This type of movement is considered normal for a 4-axis machining or is it something special? Mach3 can control it?
Attachment 249860Attachment 249862
PLEASE, SEE THE VIDEO: https://www.youtube.com/watch?v=M_cixKIquS0
another example:
https://www.youtube.com/watch?v=2ICAtxDw31M
Sorry for the question. Generally I have seen with fourth axis cuts where the cutting tool only moves upwards and axial direction (and not radial like the figure). Then I saw this video, where the cutting tool also moves laterally.
Thank you guys so much!
Vitor Spadeto Venturin
