Hi all, I'm running right now in a 3-inch thick 10.25" Diameter block of 4140. I have to mill out about 60 small parts that are about .95" TK, so I'm using a 1/4" 4-Flute AlTaN coated endmill, running about 4,000 rpm and 18.5 Inches a minute, ramping at 0.15 of a degree. The overall run takes about 12 hours, but the tool only cuts about 8 parts before breaking from excessive chip-buildup. I'm blasting coolant from four ends down into these tight slots, but it's just not doin the trick. So I'm asking you guys if you have run into anything similar?
Thanks!
-Weston
